| Prius Technical Discussion This is a discussion on Prius is lower on the driver's side within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Hi, I've had my Prius a couple of months and noticed yesterday that the driver's side is lower by 1/4 ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi, I've had my Prius a couple of months and noticed yesterday that the driver's side is lower by 1/4 inch - both front and back. I determined that by measuring the bottom trim to the floor on a flat surface. I took the car into the dealer and they confirmed the difference, but they're not sure if this is an issue. Anyone else have this difference? Thanks, - a newbie owner |
| Senior Member Join Date: Jan 2006 Location: Washington State
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(newpath @ Mar 12 2007, 07:37 PM) [snapback]404566[/snapback]</div> Quote:
What are the implications of the fact that many cars have just the driver as an occupant? That, alone, would cause the car to be tipped a little, wouldn't it? Edit: IsrAmeriPrius types faster!
__________________ White 2006 Package 8, clear bra, block heater, ScanGuage, Highlander side mouldings | |
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Probably within specs. If it bothers you, consider that the crown of the road is typically 2 to 4 percent, so you aren't really level anyway. In fact, having the driver's side lower on the springs would offset the crown a bit. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Thanks everyone, for your insight - this is a great website! Anyway, I feel better knowing this is part of Toyota's design. I only weigh 150, BTW. One thing I did learn is that Toyota service is exceptional. I went back into the garage and worked through the measuring/comparing, etc. with the technician for about an hour - extremely patient person. He actually brought in another new Prius and also put it on the alignment rack to compare (that one was off by 1/8 inch). Thanks again, all. |
| Member Join Date: Jan 2007 Location: Central NJ
My Car: 2007 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Allannde @ Mar 12 2007, 11:48 PM) [snapback]404624[/snapback]</div> Quote:
I'm just curious about this explanation -- does this mean that on a multi-lane highway, anyone driving in the left lane would actually be MORE tipped? | |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Personally, I don't think this is "by design". Note that the hybrid system under the hood is asymmetrical (left-right) compared with traditional ICE. The weight balancing (left-right) was probably overlooked by Toyota to fit into the narrow engine bay. 1/4-1/2 inch lower on one side does not bother me at all. No other vehicle I owned had this difference, though. Don't tell me this actually helps handling. That would be interesting... ![]() |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(ceric @ Mar 13 2007, 09:22 AM) [snapback]404899[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(ceric @ Mar 13 2007, 12:22 PM) [snapback]404899[/snapback]</div> Quote:
Whether by design or not, just knowing my car is not the only one with a difference is enough for me. | |
| Help with my driver side outside mirror! | priusFTW | Care, Maintenance and Troubleshooting | 5 | 05-13-2007 04:45 PM |
| Driver side air vent. | mcsj | Prius Modifications | 1 | 07-13-2006 12:00 PM |
| passenger side headlight higher than driver side | alsgameroom | Care, Maintenance and Troubleshooting | 7 | 10-21-2005 08:09 PM |
| install rear lower side spoiler | yoyoman | Prius Main Forum | 5 | 05-15-2005 06:50 PM |
| lower driver seat | thockin | Prius Modifications | 5 | 07-29-2004 07:40 AM |
