Prius Technical Discussion This is a discussion on My Prius is doing something I don't think it should do within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I have only had my Prius for a month, but I have paid attention to the Energy screen. Normally when ...
Old 03-21-2007, 08:32 PM   #1
kayemarschke2
kayemarschke2's Avatar
Send a message via Yahoo to kayemarschke2
I have only had my Prius for a month, but I have paid attention to the Energy screen. Normally when you first start up from a stop, its on battery and it shows 100 mpg. Then it goes down until you get up to speed and then back off, the mpg would go up to 50 mpg and sometimes I could get into a zone and get the 100 mpg. All of a sudden it doesn't start up with 100 mpg and when I get up to speed and back off it stays around 25 mpg and when I coast it doesn't go upn to 100 mpg. After a few minutes it goes back to what I see as normal (at least what I have learned) Anyone else have this happen?
2007 Seaside Pearl Pkg.2
Tint
Dashmat
Heat Sheild
Exactmats
Bumper Guard
Side Mouldings
XM radio
Shark Fin
HOV plate
Wood Dash
kayemarschke2 is offline
Old 03-21-2007, 08:40 PM   #2
Nominated 1 Time in 1 Post
Friends: 24
There are a ton of variables that will affect what you see on the Energy screen as the car goes through the 4 main stages of operation. Nothing you described sounds out of the ordinary to me. If you're not seeing any warning lights and the car operates normally I think you can safely ignore it.
Trust me the car continues to do unpredictable things as long as you own it!
efusco is online now
Old 03-22-2007, 07:54 AM   #3
Oxo
Oxo's Avatar
Package: T Spirit
<div class='quotetop'>QUOTE(kayemarschke2 @ Mar 21 2007, 08:32 PM) [snapback]409908[/snapback]</div>
I suggest you stop looking at the screen so much and concentrate on the road ahead. (You can switch off the screen altogether if it distracts you). Before you start a journey press the "Reset" back to zero and then at the end of your journey make a note of the MPG for that journey. Do this several times and you'll soon have an idea of what your average MPG is in different conditions. There is one 10-mile trip I do regularly with the CC set at 50 mph. Outwards it entails a slow incline upwards to about 700 feet and then downwards to my destination. For this I usually get a reading of about 55 mpg on the outward journey. On the way back it is always over 70MPG!
Oxo is offline
Old 05-18-2007, 12:41 PM   #4
chrisg67
<div class='quotetop'>QUOTE(Oxo @ Mar 22 2007, 07:54 AM) [snapback]410086[/snapback]</div>
I am approaching my second fill-up. I seem to be averaging about 44MPG. My daily commute is all highway at 75-80 mph. Relatively flat. Total miles on the vehicle is about 775. As soon as I got the vehicle I replaced the stock tires with Michellin Pilot Exalto A/S 195/60 R15. The tire place would only inflate to 34psi and said that I could deflate to 32 if I thought the ride was rough. I'm reading on here that I should have the inflation up to 42/40 (max inflation on the exaltos is 44). How much will that really help?
c.
chrisg67 is offline
Old 05-18-2007, 01:09 PM   #5
Betelgeuse
Betelgeuse's Avatar
<div class='quotetop'>QUOTE(chrisg67 @ May 18 2007, 11:41 AM) [snapback]444934[/snapback]</div>
c.
Your numbers seem totally reasonable for the type of driving you're doing. You're getting worse mileage than some people here for a few reasons: you're driving faster than is optimum for great mileage, your tires have lower inflation than is optimum for great mileage, and you replaced your OEM tires with tires which are probably not designed for low rolling resistance (although, maybe they are; I haven't gone to look it up). Note that, while the OEM tires are pretty crappy, they are good for fuel efficiency. If you were to inflate your tires to 42/40, you would probably see a modest increase in MPG (maybe up to 46 or 48 MPG); there is absolutely a measurable improvement in gas mileage that comes from inflating your tires more. Another bump would come from reducing your speed, but many people (myself included) are not willing to do that for better mileage.
Betelgeuse is offline
Old 05-19-2007, 10:04 PM   #6
chrisg67
<div class='quotetop'>QUOTE(Betelgeuse @ May 18 2007, 01:09 PM) [snapback]444963[/snapback]</div>
After I filled up for the second time, the mpg increased to 46.5 (+1.5mpg). I noticed an increase after the first fill (+1mpg) up but didn't think much about it, because I was still learning to drive the car. I will increase the tire pressure and that will get me 2mpg or so. The Exaltos are not LRR per se but they aren't horrible and they are way better than the Incrapities in just about every other way.
Either way, if I don't get any better than I am right now, I'm still getting more than 3 times what I was getting with my pickup truck (12.8mpg - yikes!).
chrisg67 is offline
