Prius Technical Discussion This is a discussion on 1G Prius engine reseal within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Gak! Someone wasn't changing their oil. . ....
LinkBack (3) Thread Tools
Old 04-03-2007, 05:07 PM   #11
ekpolk
The Regenerator
ekpolk's Avatar
ekpolk is offline
Old 10-05-2008, 09:10 PM   #12
galaxee
running WOT until out of fuel
galaxee's Avatar
Nominated 5 Times in 3 Posts
Friends: 21
Default Re: 1G Prius engine reseal
updated to put pics back into text.
galaxee is offline
Old 10-06-2008, 07:21 PM   #13
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 28
Hi Galaxee,
Thanks for reposting this string, I had not previously seen it when I was a PriusChat lurker. I understand that the root problem was an oil leak on the timing chain cover, and that it was necessary to remove the engine and transaxle to gain access to said cover. Considering the mileage and the interior condition of the engine, perhaps the owner would have been better off installing an engine from a salvage vehicle of lower miles, since it seems a salvage engine is relatively inexpensive.
Patrick Wong is offline
Old 10-12-2008, 10:34 PM   #14
galaxee
galaxee's Avatar
Friends: 21
with higher mileage engines like that, it's not unusual to see carbon buildup and a little varnish. they keep running fine that way. besides, anything you want can be tossed in a parts washer. generally speaking, if it fits it goes in when it's disassembled like that.
considering the cost would be about the same for a replacement engine, plus the seals would not be new and replaced as such, and condition of the replacement is unknown vs the known engine you've been driving on... it's kind of a toss-up as to whether it would be worth it.
when DH swapped the engine from our smashed camry into our es250, we stuck with that one because [a] we were cheap and [b] we already knew what to expect from it. (toyota learned their lesson about bottom ends with the 2vz)
black 2005 prius, tweaked just the way i like it
my diagnostic guy on electronics:
"lack of troubleshooting ability is due to a high common sense rejection ratio."
galaxee is offline
LinkBack to this Thread: http://priuschat.com/forums/prius-technical-discussion/29957-1g-prius-engine-reseal.html
Prius links This thread Refback 06-14-2008 07:01 PM
Engine pix This thread Refback 03-28-2008 10:02 PM
Prius links This thread Refback 02-10-2008 03:13 PM
Prius Engine Variants PoulStaugaard Prius Technical Discussion 11 11-06-2007 06:50 PM
engine noise 01 Prius jbondman871 Care, Maintenance and Troubleshooting 0 09-28-2007 08:23 AM
X 22 Prius - use your engine! donee Prius Main Forum 0 06-25-2007 06:15 PM
Prius engine oil analyses tochatihu Prius Main Forum 3 11-30-2005 11:59 PM
Prius Engine HP upgrades JBJAG Prius Main Forum 19 11-14-2005 12:22 AM
