Prius Technical Discussion This is a discussion on Dreaded MFD disfuntion within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I have a 2004 Prius with 45K miles on it. My MFD has started to glitch, shutting off the audio, ...
Old 03-22-2007, 12:03 PM   #1
Claude
I have a 2004 Prius with 45K miles on it. My MFD has started to glitch, shutting off the audio, blanking the miles, temp, MPG etc. It happens intermitenly.
In reading online about this, it seems Toyota has know about this for quite a while and has not offerd up a free fix. I read that one way to test if you have a faulty MFD is to see if you can switch from Energy to Consumption using the INFO switch on the steering wheel.
My Toyota dealer claims he has never heard of this problem and that they have not had any complaints on this before. He deny's ever recieving a service bulliten form Toyota on this also.
Has anyone else been able to successfully deal withthis problem? If so, what steps need to be taken to get Toyota to replace this MFD for low cost or free?
I have made an appointment withthe dealer for tomorrow so any advise would be appreciated.
Thanks
Claude is offline
Old 03-22-2007, 12:41 PM   #2
MegansPrius
GoogleMeister, AKA bongokitty
MegansPrius's Avatar
<div class='quotetop'>QUOTE(Claude @ Mar 22 2007, 01:03 PM) [snapback]410206[/snapback]</div>
Thanks
Run an advanced search with the keyword MFD in the Care, Maintenance and Troubleshooting forum and you'll see a number of threads on this, and tips for buying aftermarket MFDs.
There was a Toyota Service Bulletin on this problem for the 2004s (attached).
MegansPrius is offline
Old 03-22-2007, 12:53 PM   #3
mikepaul
mikepaul's Avatar
It may be costing Toyota too much money by now to have them offer to 'good-will' the fix for free. After I paid $89 for the diagnosis, and handed the service rep a copy of the Service Bulletin and repeated several (dozen?) times that it seemed like Toyota was letting these units die in the field despite the fact that they knew ALL of the bad ones would eventually fail, the actual repair was covered by Toyota under good-will..
Take your best shot, be firm that it sucks to find this out, point out how Toyota HAS fixed it for free on other cars, and see what you get. I'm not sure doing it for one means they HAVE to do it for all, but you can try that tactic...
2004 Seaside #9/BC as of 1/3/2004
Oil now any GOOD synthetic I can get on sale
Goodyear TripleTred 195/65R15 tires since 5/19/05
80,000 miles as of 8/22/2008
mikepaul is offline
Old 03-22-2007, 02:47 PM   #4
Nominated 1 Time in 1 Post
Friends: 24
http://priuschat.com/Source-for-refu...Ds-t26072.html
Oh, and find a different service dept or at least speak to the service dept. manager. This is a well known problem, there's clearly a TSB on it. So either they're lying or do so little work on the Prius that they're probably not competent to work on yours...in either case you're probably better somewhere else.
Again, speaking to the service manager...the head guy, not one of the service desk jockeys, and let him know about what you were told and ask how he thinks it should be dealt with. If you get satisfaction then maybe it's worth staying with them, if not then you have no choice, IMO, than to find a better service dept.
Oh, if you have the extended warranty it should be covered under that. If not you can expect to have to pay at least the $400.
efusco is online now
Old 03-22-2007, 09:51 PM   #5
Frank Hudon
failing to get Toyota to "good will" at least part of it, I'd look for a salvage one. That would be my first line of action then if unable to find one, I might consider the refurb ones that Toyota are selling. And the time to replace it is a bit more than the 2/10ths that Toyota pays but more like about 3-maybe 4 tenths. If your the least bit handy with tools and working on vehicles it's not a big job to re and re it yourself. Instructions are posted here on PC.
Frank Hudon is offline
Old 03-23-2007, 01:39 PM   #6
tvgaffer
tvgaffer's Avatar
I am having problems with mine as well and would like to know what your dealer said before I take mine in. Could you please send me a reply or an emailtvgaffer@mac.com
<div class='quotetop'>QUOTE(Claude @ Mar 22 2007, 12:03 PM) [snapback]410206[/snapback]</div>
Thanks
tvgaffer is offline
Old 03-25-2007, 01:54 AM   #7
jrmgkia
Wish I was cycling
jrmgkia's Avatar
<div class='quotetop'>QUOTE(tvgaffer @ Mar 23 2007, 11:39 AM) [snapback]411032[/snapback]</div>
I got Toyota to pay for half of the cost, I also had them use a refurbished unit so it was about $500 cost to me. Check out the full story on my My Website.
jrmgkia is offline
The Dreaded First Oil Change daveleeprius Prius Main Forum 9 05-15-2008 04:30 PM
I got the dreaded triangle daniel Prius Main Forum 12 05-15-2008 04:17 PM
The Dreaded Rattle Washington1788 Prius Main Forum 32 09-17-2007 12:25 PM
The dreaded snowflake hits Washington marjam Prius Main Forum 8 11-05-2006 11:38 PM
Dreaded MFD Failure Out of Warranty Stilview Prius Main Forum 39 07-11-2006 07:29 PM
