| Prius Technical Discussion This is a discussion on Some Hills just too steep? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Originally Posted by Rokeby OK, I'm getting very confused and concerned as to what to expect when the going gets ... |
| | #21 | |
| Senior Member Join Date: Oct 2007 Location: Gilbert, AZ
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Quote:
| | #22 |
| Senior Member Join Date: May 2008 Location: Marietta, Ga
My Car: 2008 Prius Package: #3 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Rokeby: I'm sure their will be other posts from members with experience. I'm still on the wait list and don't have our Prius yet. Howeverl perhaps I can help put your mind at ease until the more knowledgeble members reply. I've also read most, if not all off these posts. Some are unique or extreme situations or due to an equipment failure. However, I suspect alot of the incidents are just part of learning a new technology. I seen many similar situations, myself and/or other drivers. First time driving in snow/ice with automatic. First time time trying in drive up a steep hill with front wheel drive. First time you turn off the iginition off coasting downhill from Lookout Mountain's windy mountain road only to remember, too late, that a new feature on the car is a locking steering wheel. I honestly believe that it's more of a matter of learning the differences and how to put them to best use, than deficiencies in the Prius. That's only my observation and I've already proven that I can be wrong. Hope the helps until you get some real advice.
__________________ Dave & Joan, wishing all "Happy Motoring" 2008 Prius Touring CVT on-order, Seaside Pearl, Dark Grey Leather, Pkg#3 2000 Toyota Avalon XLS, Silver Spruce, 111K+, Extremely satisfied original owners. |
| | #24 | |
| A young senior member Join Date: Mar 2006 Location: Chicagoland, IL USA, Earth
My Car: 2006 Prius Package: #1 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Quote:
Others have reported their wheels just don't turn at all in these conditions, including people experienced in driving snowy and rough conditions (like Jayman). I don't know if the cars are programmed differently, if it's a matter of year and package or what. I haven't seen a clear difference that could be pointed to. One person I think said their 2004 had the problem until they had a recall which reprogrammed one of the car's computers. My recommendation is to try this out someplace safe and get a feel for it on your car before you need it. Worst case, you may need to get out and walk up a driveway or scout out a different route in bad weather. Don't think you're entitled to get everywhere a road goes in all conditions. Perhaps use tires with better traction if this is something that can happen often. Regarding the original situation, I remember in my 1987 Nissan Sentra (FWD) going up a road that became very steep with loose rock. That was one of the scariest moments I ever had while driving, because the front wheels started slipping (gravel would have been okay at that pitch, but not loose rock). I knew if I stopped I wouldn't be able to continue, and backing down such a steep road with trees right on the edge would be very treacherous. No place to turn around, and any bit of momentum downhill and the brakes would just cause me to skid backwards. Fortunately I was able to continue to where the road leveled out and I think I found a different way out.
__________________ "We must be the change we seek" - Gandhi Last edited by nerfer; 08-08-2008 at 02:13 PM. Reason: Added info on tires | |
| | #25 |
My Car: 2007 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I have a 2007 and haven't had any problems with wheel slip. The "change" to the traction control is thought to have occurred early in 2005. They can't reprogram older units, they have to replace the traction control module from what I've read. The OEM 15" Goodyear Integrity tires are responsible for most of the problem. The "touring" 16" Bridgestone tires are supposed to be much better. I replaced my Goodyear Integrity tires last September, before my first winter. I put on "real" all season tires, Nokian WRs. But 2004 and early 2005 owners are still reporting too-sensitive traction control problems, even with very good tires.
| | #26 | |
| Junior Member Join Date: May 2008 Location: Texas
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Forget the Highlander, get a 4 WD RAV 4. I have a 2007 and can go just about anyplace I desire! It is a great vehicle. Check out the Rav4 for off roading. Quote:
| | #27 |
| Junior Member Join Date: Jul 2008
My Car: Other Non-Hybrid Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | 2008 Prius. Pedal pressed all the time to the floor on unpaved hill after rain. IMHO in this case TRAC system works pretty well. Videos are on RapidShare server RapidShare: Easy Filehosting RapidShare: Easy Filehosting Last edited by rav04; 08-09-2008 at 06:16 AM. |
| | #29 |
| LifesaBeach Join Date: Apr 2008 Location: CALIFORNIA
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | I know this is a safety device for both the car and the driver, but it must be able to be fixed. In times you may need it the most the car will no longer work. That is pretty sad and dangerous. |
| | #30 | |
| Sapphire of the Blue Sky Join Date: Apr 2007 Location: Virginia
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
I've heard that "flooring" it will make the traction control lessen up a bit to enable you to go faster... | |
| Going up steep gravel driveway | adaprill | Prius Main Forum | 24 | 02-09-2008 02:29 PM |
| VSC, can it be disabled? (Steep driveway) | seftonde | Prius Main Forum | 6 | 11-20-2007 05:25 PM |
| Steep snowy driveway | johnmcsoft | Prius Main Forum | 18 | 07-06-2006 11:27 PM |
| Steep driveway = Prius scraping | elmofongo | Prius Main Forum | 7 | 07-06-2006 01:21 PM |
| backing up a steep hill | northvan | Prius Main Forum | 5 | 02-11-2006 01:59 PM |
