Prius Technical Discussion This is a discussion on Verizon VZ Navigator within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; This may be technically, or pracitcally impossible; but, I just signed up for Verizon VZ Navigator service, which is a ...
Old 06-22-2007, 07:18 PM   #1
emesss
This may be technically, or pracitcally impossible; but, I just signed up for Verizon VZ Navigator service, which is a fairly good GPS that runs on my Verizon phone. The phone is linked to my Prius. Is there any way to run, or at least display, the GPS results on the Prius screen.
Nothing seems obvious, but I am just an egg.
emesss is offline
Old 06-22-2007, 08:56 PM   #2
Rangerdavid
Rangerdavid's Avatar
Friends: 11
excellent question, the answer to which I do not know. I do not have the factory nav in my prius, but I wonder (1) does the Verizon nav give voice turn by turn direction? and if so, (2) if I'm connected via bluetooth, if not the video, would the Prius broadcast the turn by turn directions? <_<
Rangerdavid is offline
Old 06-22-2007, 09:45 PM   #3
emesss
<div class='quotetop'>QUOTE(Rangerdavid @ Jun 22 2007, 08:56 PM) [snapback]466667[/snapback]</div>
We do not have the nav system either; but, the Verizon does announce turn by turn, and we will attempt to have the system broadcast the voice.
emesss is offline
Old 06-25-2007, 05:08 PM   #4
alanh
You're not going to get anything on the screen, 100% sure of that.
I'm not sure on the audio.
alanh is offline
Old 06-26-2007, 09:49 PM   #5
Birdums
You, me, and da Pri
Birdums's Avatar
<div class='quotetop'>QUOTE(emesss @ Jun 22 2007, 07:18 PM) [snapback]466620[/snapback]</div>
I love VZ Navigator! I download it only when I am on vacation, use it for that month only, then delete it until I need it again. It's totally worth the 10 bucks to find my way around a strange place. Gotta watch that battery, though; it can drain your phone.
I don't know of any way to display it on the MFD, and because it's not quite a 'call', I dunno about the voice coming thru BT, either. I sure hope it does.
'DuPree'
Silver Pine Mica
mud guards
35% tint all around
window visors
clear all-weather mats
removed plastic wheel trim rings
FireEngineer special EBH
Birdums is offline
Old 09-01-2007, 10:45 PM   #6
Sleeztak
<div class='quotetop'>QUOTE(You me and da Pri @ Jun 26 2007, 09:49 PM) [snapback]468594[/snapback]</div>
I tried it today and received no voice while the phone was connected to the BT. I turned the BT of the phone off and then got nav with voice. VZ nav is a really nice navigation system. 2.99 a day or 10.00 for the month. I would love to have it on the MFD though.
Sleeztak is offline
Old 05-18-2008, 06:52 PM   #7
Prius_jan
Default Re: Verizon VZ Navigator
I have not been able to use my VZ Navigator from my cell phone in my new 2008 Prius. It won't run at all when it's on bluetooth and when I disconnect the bluetooth it runs very slowly and won't talk. Does anyone have a solution?
Prius_jan is offline
Old 05-20-2008, 12:06 AM   #8
Rest
Not at those prices it's not.
Rest is offline
Old 05-20-2008, 07:21 AM   #9
rsforkner
rsforkner's Avatar
I am planning on a 2.5 week vacation this August and plan to use the VZ Navigator during that time. Sounds like an excellent plan. I'll be visiting friends that live in some pretty remote locations. Does the GPS directions work out of tower range?
Thanks for the affirmation on it's value. And thanks for the tip on the battery. I'll keep the 12V charger handy. Sounds like a good alternative to spending several hundred dollars on a GPS that would only get used once or twice a year. I don't need GPS around home. I know were everything is!
Bob
  1. Every hour, everyone needs a smile.
  2. Every day, everyone needs a good belly laugh.
  3. Every week, everyone needs to laugh so hard that milk shoots out of their nose.
Mods: Reverse Beep, Window Tint, Wheel Rings gone, Unlock all Doors, Dash Topper, Window Guards ordered, more to come
rsforkner is offline
Old 08-30-2008, 04:35 PM   #10
lorimarie
Angry Re: Verizon VZ Navigator
I have a similar problem. My vznavigator worked with a motorola hands free bluetooth system, but not with the bluetooth in my 2008 prius. The phone functions work fine, but not the navigator voice prompts. Unfortunately, when the phone is paired, the audio from the phone itself is disabled. further, if I use the headphone jack through the audio accessory input from the prius, the voice prompts work, but the bluetooth is disconnected, so I cannot use the phone!
Anyone out there find a solution to this problem?
lorimarie is offline
Help Wanted: Navigator for Hybridfest MPG Challenge efusco Prius Main Forum 8 07-18-2007 09:20 PM
Have You Given Your Navigator-Lady-Voice a Name? Mister Swigart Prius Main Forum 26 03-27-2007 09:18 PM
Navigator jkash Prius Main Forum 12 08-01-2004 12:16 PM
The 10 Gallon Vacation - Navigator Vs Prius Tempus Prius and Hybrid News 5 06-10-2004 12:54 PM
Navigator and first wave jkash Prius Main Forum 0 05-16-2004 10:35 PM
