| Prius Technical Discussion This is a discussion on Tire upgrade and pressure sensor question within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I'm going to swap OEM tires for GY Comfortreads, same size. Do the pressure sensors need to be recalibrated if ... |
| Senior Member Join Date: Jul 2006 Location: Texas
My Car: 2006 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I'm going to swap OEM tires for GY Comfortreads, same size. Do the pressure sensors need to be recalibrated if moved to another same size tire? Thanks. |
My Car: 2001 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Dr Ed @ Jul 29 2007, 12:54 AM) [snapback]486950[/snapback]</div> Quote:
My Car: 2007 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The tire size has no effect on sensor calibration. The tire sensor measures pressure inside the tire, and compares it to the setting you make once in a while when you press the button (after you check and inflate/deflate appropriately). So once you have the new tires on the car, inflated correctly to your choice of pressure, press the button. |
| Member Join Date: Aug 2007 Location: Bastrop, TX
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(David Beale @ Jul 29 2007, 12:23 PM) [snapback]487106[/snapback]</div> Quote:
Thanks! John | |
My Car: 2007 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | They have a lithium primary battery (not chargeable) and it's not replaceable. Five to ten year life is my guess. Probably you would want to replace them by that time, as the valve stem would have started looking a little the worse for wear, and it's part of the sensor. Or just live without them. They are there as a "cover your ass" idea from politicians/bureaucrats. They aren't really needed if you look after your car and check tire pressures once a month, like you're supposed to. |
| Shuttlecraft Commander Join Date: Jun 2007 Location: Out there, somewhere
My Car: 2007 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 8 | As I recall from a previous discussion, the tire pressure sensors only activate when one has lost 10 pounds of pressure or something like that. SO-O-O-O, could one sensitize the sensor system by inflating one's tires all the way to their maximum (or beyond if you dare), pushing the reset button, and then deflating the tires to the operating pressure? These things are still crude, but it seems to me that this would increase the sensitivity. |
My Car: 2007 Prius Package: #5 Nominated 6 Times in 1 Post TOTM Awards: 1Friends: 53 | They report a differential pressure change of 25%; that is, when the pressure has decreased by 25% from the pressure at which the button was pressed, the warning light comes on. The recommended 2 psi pressure difference between the front and rear tires has no effect since TPMS measures each tire's pressure. If you want less than a 25% drop warning, increase your tire pressure, reset the TPMS, deflate your tires to your running pressure. The difference between set pressure and running pressure will come out of the 25% and you'll get an earlier warning if your pressure drops.
__________________ Bill Bill.Merchant@PortlandHSD.info 2007 NL 5 Silver Wraith 2005 BC 6 Silver CloudPortland Area HSD Meetup Group: PortlandHSD.info Become carbon neutral: Carbonfund.org or TerraPass.com |
| Senior Member Join Date: Apr 2007 Location: S.F. Bay Area
My Car: 2007 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(David Beale @ Aug 15 2007, 09:13 AM) [snapback]496174[/snapback]</div> Quote:
My Car: 2001 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(apriusfan @ Aug 17 2007, 12:09 PM) [snapback]497862[/snapback]</div> Quote:
My Car: 2007 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(FL_Prius_Driver @ Aug 17 2007, 03:21 PM) [snapback]498051[/snapback]</div> Quote:
| tire shop broke a TPMS tire pressure monitor sensor during tire change | theorist | Care, Maintenance and Troubleshooting | 28 | 04-18-2008 12:53 PM |
| Tire Pressure Sensor Question | peach | Prius Main Forum | 7 | 07-26-2007 12:39 PM |
| question about the tire pressure sensor | hybrid_batmobile | Prius Main Forum | 2 | 12-27-2006 04:01 PM |
| Tire pressure sensor | mssmith95 | Prius Main Forum | 2 | 06-04-2006 02:09 PM |
| Tire Pressure Monitor, where is the sensor? | DocVijay | Prius Main Forum | 28 | 12-19-2005 06:08 PM |
