| Prius Technical Discussion This is a discussion on Spontaneously aborted S4 glides at 26 MPH within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Thanks for the responses. What everyone says makes sense, and the agreement seems to be that the heat, especially in ... |
| | #11 |
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Thanks for the responses. What everyone says makes sense, and the agreement seems to be that the heat, especially in the battery, was the cause. But again, has anyone seen a glide interrupt itself part-way through? Why at a consistent 26 MPH? And why did the anomaly stop even though the battery temp didn't change after that? I welcome educated guesses in the absence of first-hand experience or knowledge. |
| | #12 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The threshold of how much current you can draw probably went down, so the whole system probably became much more sensitive to demand. The other little wrinkle is that short period of engine-running when the secondary cooling loop opens via the 3-way valve; the engine tends to run long enough for the water pump to push stuff through that piece of the loop [incl. the bottle] and make sure it's all warm. That can yield a small period of frustration, but then it sorts itself out again. Yup, it happens in stage 4 too. . _H* |
| | #13 |
| Senior Member Join Date: Apr 2008 Location: Boynton Beach, FL, USA
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | I don't think this is too far off topic.... Where does the exhaust air from cooling the battery go? Is it vented outside the car or back into the passenger compartment? If outside, where is the vent and how does blowing all that cool air outside affect the AC load? I know it is needed to cool the battery but just wondered about the additional load on the AC. Just sounds like driving a "regular" car AC with the windows down. Bob Last edited by rsforkner; 06-12-2008 at 10:27 AM. Reason: typo |
| | #14 |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 24 | The air exits near the 12v battery on the back rear side of the car to the outside of the vehicle. I have a really nice photo, created by Wayne Brown, that I like to post that shows the air flow very nicely, but my dang work blocks my image hosting site....bastards. |
