| Prius Technical Discussion This is a discussion on When do you use the EV button? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I always find it amusing when people respond to EV button questions by correctly explaining that to get a fuel ... |
| | #21 |
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I always find it amusing when people respond to EV button questions by correctly explaining that to get a fuel efficiency improvement from it you have to know when it is beneficial, or by correctly explaining that incorrect use can actually reduce fuel efficiency, and then go on to explain the situations in which they use it which turn out to be situations where they are reducing their overall fuel efficiency. |
| | #23 |
My Car: 2006 Prius Package: #7 Nominated 7 Times in 2 Posts TOTM Awards: 0 Friends: 18 | With my use of the EV button I can constantly get my first 5 min bar in the 45-55mpg range or on the Can-View the first mile is 40+mpg and the next 2 miles are 50+mpg. This is because I have a short streach of slow road that I have to travel to get to another road that has a speed limit of 55mph. When starting out from work its all city driving for about 5 miles. During this time I use the EV button to P&G between 34mph and 25mph. |
| | #24 |
| Senior Member Join Date: Mar 2007 Location: West Palm Beach, FLA
My Car: Package: Nominated 3 Times in 1 Post TOTM Awards: 0 Friends: 5 | One other thought folks,..... the HV ECU still retains the programming for the EV switch, but does the Engine ECU have the proper program to allow for it? And even though the HV ECU has the hardwire connection for the switch, does it's programming allow for it's proper operation? And finally, does the HV Battery ECU have the proper programming to allow for such wide swings in it's SOC? As a tech, I find it frustrating when I encounter an issue with a car that the repair manuals don't have enough information to help me solve. When the book says "Test with known good component", I cringe. The parts dept doesn't exist the can hold all the "known good components" that might be needed over the course of a months time in a busy shop. If the engineers who designed the cars won't give Toyota techs all the info needed to find and fix problems, how do we know what can happen with a part they didn't intend to be in the cars they send to the US? ![]()
__________________ Toyota Ceritified Master Diagnostic Tech, Prius Certified "The only foolish question is the one left unasked." |
| | #25 | |
| Senior Member Join Date: Jun 2007 Location: Augusta, GA
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Danny Hamilton @ Aug 10 2007, 10:43 AM) [snapback]493516[/snapback]</div> Quote:
__________________ D Rock Removed wheel trim rings($0), Heat shields(mostly use windshield one since I have tint now) all the way around($120), BT Plate($165), EBH($39), 195/65 R15 Bridgestone Turanza LS-T tires at 42/40(now discontinued $340), Weather tech window vent shields($120), Zaino wax system($93), Scan Guage II($149), Nushield MFD screen protector($19), MFD hood(sun glare reducer $34), Fumoto 103N oil drain plug($21), Daryl the EV nut's Magnificient SUPER LED upgraded interior lights($434), Blocked upper grill($1.42), 35% window tint except front windshield LLumar brand($175), Mud flaps($36) what is next LOL? | |
| | #26 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Bear68 @ Aug 9 2007, 09:24 PM) [snapback]493311[/snapback]</div> Quote:
| | #27 |
| Senior Member Join Date: Jul 2007 Location: Sydney, Australia
My Car: 2007 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Like those responses from the UK, the EV switch is standard here in Australia. I use mine when visiting my mother. Something that I need do once or twice a week. She lives in a retirement village with 10 kph speed limits, but with just enough rises and falls that almost force you to use the ICE just to keep rolling. Everyone tries to keep the noise down in the village - I can just do it better than the rest I also use it when getting home late at night. Just being kind to the neighbours. I certainly have not seen any negative impact on fuel usage - just better mpg. I do let the ICE kick in when starting, and find that any charge used when running in EV is very quickly replaced, but still with minimal impact on the mpg.
__________________ Eric Crystal Blue 2007 Prius Base Model - Schneider reversing camera added |
| | #28 | |
| Senior Member Join Date: Sep 2005 Location: Oxfordshire, UK
My Car: 2005 Prius Package: T Spirit Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Bear68 @ Aug 8 2007, 08:02 PM) [snapback]492743[/snapback]</div> Quote:
Unless you frequently have to move the car a very short distance I doubt whether it will improve your mpg significantly but this is just a hunch. It's not worth the cost of installing in a car you're using unless you just like the novelty of it. | |
| | #29 |
| Join Date: Dec 2005 Location: Springfield, VA (Northern VA)
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I think it was on TV I saw that the US Highlander was going to have EV factory installed? I haven't been to PC as often as I was when my car was new but I haven't seen mention of this. I have not installed the EV in my '06, primary reason was warranty issue. |
| | #30 |
| Senior Member Join Date: May 2007 Location: SF Bay Area, California
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | No one here knows what they are talking about, but I don't want to explain why, because then someone might find a fault with my reasoning. Therefore, I will just say everyone is wrong and sit here smugly. |
| EV button OEM 06' (again) | smontminy | Prius Main Forum | 2 | 01-02-2007 08:03 PM |
| Help with EV button!!! | PriusLuver | Prius Main Forum | 3 | 11-05-2006 11:28 AM |
| Odd FM button.... | ttabbal | Audio and Electronics | 3 | 03-27-2006 01:36 PM |
| EV Button | HIHOAG | Prius Modifications | 59 | 10-13-2004 11:41 PM |
| Ev button | Raenstoirm | Audio and Electronics | 2 | 04-20-2004 12:45 AM |
