| Prius Technical Discussion This is a discussion on What Gas Octane do you use ? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(viking31 @ Aug 20 2007, 01:55 PM) [snapback]499218[/snapback]</div> Engine problems with higher octane? What problems? Rick #4 2006 [/b] ... |
| | #21 | |
| Member Join Date: Jul 2006 Location: Bradenton fl area
My Car: 2006 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(viking31 @ Aug 20 2007, 01:55 PM) [snapback]499218[/snapback]</div> Quote:
For starters, burned exhaust valves. It's never been mentioned here, but it can do just that. The slower burning higher octane fuel will still be burning when the exhaust valve opens. | |
| | #22 | |
| Certified Prius Advisor Join Date: Nov 2006 Location: South Jersey
My Car: 2006 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(mastermason11 @ Aug 19 2007, 03:42 AM) [snapback]498587[/snapback]</div> Quote:
| | #23 | |
My Car: 2007 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(prius2go @ Aug 20 2007, 11:59 AM) [snapback]499255[/snapback]</div> Quote:
Icarus | |
| | #24 | |
| Senior Member Join Date: Aug 2007 Location: Tulsa, Oklahoma
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(bapajack @ Aug 19 2007, 07:45 AM) [snapback]498619[/snapback]</div> Quote:
Ethanol has a high affinity for water and usually, in an older car, will clean out your fuel system and carry all of the debris into the fuel filter causing possible plugging problems. Last, but, not least, ethanol can soften and, over a period of time, damage/destroy some rubber and rubber seal and o-ring compounds. Thus, causing leaking gasoline seals and o-rings wherever they come into contact. Does anyone know the rubber compound used in the Prius fuel system o-rings, seals and elastomers? In the petroleum industry, we normal specify Viton "A" seals for all ethanol handling uses. It is a higher grade of rubber than Buna "N", which many non-critical seals and made from because it is a cheaper rubber compound. This is why some cars are specified as okay for Ethanol blended gasolines and some are not. Does the Pruis Owners Manual specify ethanol blended fuels as okay for use? Hope this helps!!
__________________ Hers - 2008 Barcelona Red Touring Pkg #6 Mods: No reverse or seat belt beeps All weather floor mats Tinting 35% Ceramic all-around Mud Flaps 40F/38R His - 2008 Driftwood Pearl Touring Pkg #6 Mods: No reverse or seat belt beeps All weather floor mats Tinting 20% Ceramic all-around Mud Flaps 40F/38R Hexomat Cargo Liner GO COWBOYS !!!! | |
| | #25 | |
My Car: 2005 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | <div class='quotetop'>QUOTE(Sliderule @ Aug 20 2007, 08:21 PM) [snapback]499518[/snapback]</div> Quote:
| | #26 |
My Car: 2004 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 17 | E10 is good in mine, I ran my Camry on E10 and it ran better and got better economy than on standard petrol. E10 is cheaper than standard, it has slightly lower calorific value than standard unleaded but in my camry it stopped the pinging and improved economy. I'm getting about 4.4l/100km which is the rated estimated consumption city cycle from the Prius on it so economy isn't suffering. Ethanol in Australia is made from sugar cane waste. |
| | #27 | |
| /dev/geek Join Date: Jan 2006 Location: San Francisco Bay Area, CA
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(mastermason11 @ Aug 19 2007, 11:24 PM) [snapback]499018[/snapback]</div> Quote:
| | #29 |
| Senior Member Join Date: May 2007 Location: Phoenix, AZ
My Car: 2007 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | E10 is required in many urban areas due to pollution issues, and that MTBE is no longer allowed. Anyway... all the octane does is resist knocking. If you're not knocking, extra octane will do nothing for you. |
| | #30 |
| Senior Member Join Date: May 2007 Location: SF Bay Area, California
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Regarding the Montana Gas question; At higher altitudes, the air is less dense, so your cars engine takes in less mass of air. That makes it harder to ignite the fuel. In order to help with the fuel ignition, they reduce the octane of gasoline sold at higher altitudes. The gas you are talking about must have been sold at a high altitude gas station. |
| which octane ? | whitewhiskers | Prius Main Forum | 9 | 03-28-2007 08:27 PM |
| 87 octane regular vs 89 octane 10% ethanol | captain archer | Fuel Economy | 8 | 10-25-2006 01:51 AM |
| Octane Level's | Prakash | Prius Main Forum | 31 | 03-25-2006 06:01 PM |
| Best octane? | yoda | Prius Main Forum | 45 | 03-06-2006 07:41 PM |
| Octane Vs Gas Mileage | Bob259 | Fuel Economy | 4 | 04-14-2005 12:30 AM |
