Prius Technical Discussion This is a discussion on Reverse Gear Alarm within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; First post.... I tried the search function and no luck. Reverse beeper, is there a way to shut it off? ...
Old 08-21-2007, 08:14 AM   #1
Nhuskys
First post.... I tried the search function and no luck. Reverse beeper, is there a way to shut it off? My daughter has to take her drivers test and finds it really distracting when she is parrallel parking. Great forum!
Norman
Nhuskys is offline
Old 08-21-2007, 08:21 AM   #2
tekn0wledg
# Power on the car, Cycle ODO/TRIP, stopping on ODO, Power off the car.
# Power on, within 6 seconds, hold ODO for at least 10 seconds.
# While still holding ODO shift into Reverse and back into Park.
# b-on shows on speedometer display, press ODO to cycle to "b-off".
# Power off the car
tekn0wledg is offline
Old 08-21-2007, 08:22 AM   #3
gazz
gazz's Avatar
Package: T4
<div class='quotetop'>QUOTE(Nhuskys @ Aug 21 2007, 07:14 AM) [snapback]499668[/snapback]</div>
Norman
Try this
In order to disable the reverse beeping on your 2007 Prius, follow these instructions:
1. Without your foot on the brake, turn on your Prius and make sure you are in ODO mode (not Trip A or . Power off the Prius
2. With your foot on the brake, turn on the Prius. As soon as the ‘Ready’ light is lit, press and hold the ODO button for at least 10 seconds.
3. Keeping the ODO button pressed, move the shifter to Reverse and release, then press the Park button again. At this point, ‘b- on’ should appear on your dashboard display.
4. You can now let go of the ODO button, and each press of the ODO button toggles between ‘b-on’ and ‘b-off’. To disable the reverse beep, simply set it to ‘b-off’, the power off the Prius.
This does not work on European models, does anybody know how to do this on a UK model.
gazz is offline
Old 08-21-2007, 09:34 AM   #4
Friends: 6
http://www.evnut.com/prius_beeper_disable.htm
Old 08-21-2007, 09:45 AM   #5
Errel
Errel's Avatar
I am also annoyed by this reverse beeping noice! Can anybody help us pleeeeeease!
Errel is offline
Old 08-21-2007, 09:46 AM   #6
Nhuskys
Many thanks for the replies!
Norman
Nhuskys is offline
Old 08-21-2007, 09:55 AM   #7
Errel
Errel's Avatar
<div class='quotetop'>QUOTE(tekn0wledg @ Aug 21 2007, 08:21 AM) [snapback]499670[/snapback]</div>
# Power off the car
Will this apply to all Prius 04-07? I will still try it.
Errel is offline
Old 08-26-2007, 11:43 PM   #8
msiguy
<div class='quotetop'>QUOTE(Nhuskys @ Aug 21 2007, 08:14 AM) [snapback]499668[/snapback]</div>
Norman
Try this:
<http://www.wikihow.com/Disable-Reverse-Beep-in-a-Toyota-Prius>
Good luck.
msiguy is offline
Old 08-27-2007, 11:06 PM   #9
JimN
Certified Prius Advisor
JimN's Avatar
John's site has a ton of useful info:
http://john1701a.com/
JimN is offline
will not stay in gear harryg Care, Maintenance and Troubleshooting 4 06-15-2007 02:56 PM
Out of gear tfelder Care, Maintenance and Troubleshooting 7 07-19-2006 08:31 PM
Security Alarm too quiet? Does alarm trigger shut down? crtolin Prius Main Forum 4 06-20-2005 05:09 PM
Park gear jeepien Prius Main Forum 61 04-11-2005 12:50 AM
The [B] gear?? senectus Prius Main Forum 29 03-01-2005 08:24 PM
