Prius Technical Discussion This is a discussion on Idle noise in Park within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; When I sit in the car while it is "idling" although the ICE may be off, I hear a "click" ...
Old 08-23-2007, 12:31 PM   #1
AVOID92X
When I sit in the car while it is "idling" although the ICE may be off, I hear a "click" noise cycle on about every 10 seconds coming from mid-dash, engine bay. I am sitting inside the car.
What is this? The coolant pump, like when you turn the car off?
AVOID92X is offline
Old 08-23-2007, 01:30 PM   #2
Friends: 5
The brake accumulator pump makes a clicking noise. It comes from somewhere down behind the peddles. Whatever it is, it shouldn't be running every 10 seconds. The accumulator pump runs about every third time you press the brake peddle. Frequent cycling can indicate a leak.
Old 08-24-2007, 07:01 PM   #3
TomSwift
Is the AC running? I recall hearing some clicking when I had the the AC running and the compressor started or shut down. To test this turn off the AC and see if the sound goes away.
TomSwift is offline
Engine idle changeover (ICE to ELECTRIC) smokey1 Care, Maintenance and Troubleshooting 5 03-06-2007 01:11 PM
Disable Idle Creep! haiyue Prius Modifications 14 06-23-2005 11:22 AM
Idle Charge mss Prius Main Forum 5 04-13-2005 12:40 AM
Rough Idle htmlspinnr Care, Maintenance and Troubleshooting 35 02-26-2005 08:49 PM
How to get the Prius to idle. pino Care, Maintenance and Troubleshooting 14 12-15-2004 06:05 AM
