| Prius Technical Discussion This is a discussion on update on 01 prius battery within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; issues on the prius are slowly coming back to normal im averaging constantly 45-52 mpg now, not the 60-80 mpg ... |
My Car: 2005 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | issues on the prius are slowly coming back to normal im averaging constantly 45-52 mpg now, not the 60-80 mpg in every driving condition i had before. my guess is being that the car was sitting for a long period of time, it caused something to happen to the battery. the power is back to normal also, 0-60 times are almost normal for a 01 prius, but low end torque is extremely high, i still lose traction on dry pavement from a stop, making turns to a 50 mph road requires careful use of accelerator pedal, as the tires will spin a lot even at 1/4 throttle. other than that, battery fan noise as subsided. anyone know if temperature of HV battery corellates to power produced by electric motor. Another thing, the electric motor on the nhw11, and nhw20 prius are 3 phase electric motors correct? and output of battery power specifically on NHW11, gets converted to the 3 phase power to give power to electric motors correct? then it goes 273 volts DC from HV battery to inverter then outputs it to 3 phase AC for the motors at the same voltage correct? so technically if the above is true for the NHW11 the output of the Hv battery increased, so would the output of the electric motors? if this is all true, this wouldnt apply to the NHW 20 since it has a boost converter correct?
__________________ 2005 Toyota Prius Hybrid Package 9 2001 Toyota Prius 2005 Honda Accord Hybrid 3.0 V6 |
My Car: 2001 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(statultra @ Sep 1 2007, 11:10 PM) [snapback]505645[/snapback]</div> Quote:
2) On the NHW 11, the inverter and battery operate at about the same voltage. By intellegently controlling the timing of the transistors that send the DC voltage to the specific phase of the motor/generators, the current flow between the the two M/Gs and the battery is controlled to match what is wanted. These algorithms are really involved. On the NHW20, there is a voltage doubling converter that takes the 200 HV battery voltage and increases it to about 500 volts. This extra conversion allows for higher efficiencies in the motors. 3) The motors of the NHW11 and NHW20 are wound differently. The NHW20 converted the parallel windings of the NHW11 to series windings to take advantage of the higher voltage. This also allows more power to be sent to the motor. | |
My Car: 2006 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(MichaelE @ Sep 8 2007, 09:32 PM) [snapback]509272[/snapback]</div> Quote:
By taking the battery and reversing it into the motor windings. This is what the Inverter Bridge circuit does. First it hooks the battery positive to coil positive, negative to negative, then it hooks the battery positive to coil negative and negative to positive. So the coil sees voltage one-way, then the other. If done quickly enought, the current is limited by the winding inductance. For each phase (group of windings with a 360/N, where N is the number of phases, position around the diameter) there is a bridge circuit. So that the current peaks (magnetic field peaks) in each phase can proceed around the outside diameter of motor. And the permanent magnets get pulled to those magnetic field peaks. So, a 3 phase motor has 9 windings, which are hooked together in groups of three. Its called brushless DC, as it only needs a DC source into the motor drive (electronics) to run the motor, and it has little induced (reluctance) field. The typical mechanically comutated (coil-switched) DC motor requires brushes (sliding contacts) that make contact with various coil elements in the wound rotor of a DC motor. Due to the smaller size, and problematic cooling of the rotor, wound rotor motors are lower power, and is not nearly as durable. A brushless DC motor is built just like a three-phase AC synchrounous motor, with the coils on the inside of the stator housing and a iron rotor core. But rather than having an induction rotor core, it has a permanent magnet field rotor core. So the commutation of the coils is external to the motor, and electronic. Additionally, all coils can be driven simutaneously, but at different phases, giving excellent torque. The typical AC motor, like the blower motor in your furnace, is an AC induction motor. It has no permanent magnets, and magnetic field is due to currents that flow in a cast aluminum conductor (socalled squirel-cage construction) that is internal to the iron core rotor. The current is induced from the magnetic fields in the stator windings. Ever notice these motor cores have an aluminum hub? That is the root of all the coil elements that are imbeded in the iron, and its cast all at once. These motors are not perfectly synchrounous. There has to be a little slip between the rotating field and the rotation RPM of the rotor to generate the current in the rotor. This is why its common for these motors to be like 1725 RPM, rather than 1800 (an interger fraction/multiple of 60 Hz). Toyota actually specifies the Gen II motor as a synchronous AC motor. Which is correct also, but not common US motor terminology. | |
| UPDATE ON MY NON RUNNING 02 PRIUS | baddad457 | Prius Technical Discussion | 30 | 10-05-2007 03:10 PM |
| 05 Prius--Nav System CD Update? | casey961 | Care, Maintenance and Troubleshooting | 3 | 09-03-2007 03:14 AM |
| New Prius, update radio? | acdii | Audio and Electronics | 12 | 04-14-2007 06:32 PM |
| An update to my issue with the battery.... | supernole1 | Prius Main Forum | 1 | 04-11-2006 10:15 PM |
| Any plans for a Prius software update? | ThetaSigma99 | Audio and Electronics | 2 | 03-10-2005 03:39 PM |
