Prius Technical Discussion This is a discussion on Programming "Wait" and "Pause" In Phone Numbers within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I am now at the point where I want to start programming the speed dials in my 2007 Prius Bluetooth ...
Old 09-10-2007, 03:59 PM   #1
jarrett_gorin
I am now at the point where I want to start programming the speed dials in my 2007 Prius Bluetooth phone application. I can see easily how to add a new speed dial number.
My question is this: Is there a way to add pause and wait characters to a dialing string so that you can select one of the speed dials on the MFD, have it dial the number you want (like your voice mail) wait a few seconds, and then dial a second set of numbers (like your password) automatically? I have looked all over the documentation and can't find a description of "pause" or "wait" characters anywhere.
Any info on this would be greatly appreciated. Thanks.
Jarrett Gorin
Santa Barbara, California USA
jarrett_gorin is offline
Old 09-10-2007, 07:38 PM   #2
jarrett_gorin
<div class='quotetop'>QUOTE(JG in SB @ Sep 10 2007, 12:59 PM) [snapback]510208[/snapback]</div>
Here I go answering my own question......
I decided to program a few numbers today that did not require waits or pauses in the dialing string. While doing so, I noticed, clearly visible to the right of the numbers on the MFD, a "wait" button and a "pause" button. I haven't tried them, but I will speculate that these do exactly what I was looking for. I look forward to testing them out.
Old 09-11-2007, 09:18 AM   #3
9G-man
<div class='quotetop'>QUOTE(JG in SB @ Sep 10 2007, 07:38 PM) [snapback]510321[/snapback]</div>
They are programmed as "p" pause and "w" wait extensions to phone numbers in your phone book. The saved phone number in your phone book would look like this example: 678-463-4569w2212. Where 2212 is the extension for that phone number. When the number is dialed, and connection is made, you then push the "Send Tone" button, and the 2212 extension will be dialed..
Works like it does in your cell phone. And your cell phone manual probably has a better explaination than the prius manual. The explaination for this feature in pretty much non-existent in the prius manual.
9G-man is offline
Old 09-11-2007, 04:10 PM   #4
jarrett_gorin
<div class='quotetop'>QUOTE(9G-man @ Sep 11 2007, 06:18 AM) [snapback]510545[/snapback]</div>
........ your cell phone manual probably has a better explaination than the prius manual. The explaination for this feature in pretty much non-existent in the prius manual.
Explanation of this and other things too. Thank goodness for this forum!! Do you happen to know how long of a pause the "p" character will produce? I can figure this out by trial and error, but if I can find out in advance that would be ideal.
Old 09-17-2007, 12:50 PM   #5
MHarris
<div class='quotetop'>QUOTE(JG in SB @ Sep 10 2007, 06:38 PM) [snapback]510321[/snapback]</div>
Problem is you can't press SEND while moving, so you can't program a number that needs a pause on speed dial (to dial while moving). At least that's how it seems.
MHarris is offline
Old 09-17-2007, 02:49 PM   #6
Ichabod
Artist In Residence
Ichabod's Avatar
Send a message via AIM to Ichabod
Friends: 7
I've been frustrated by this feature more than once. I'm not sure if it's a bug in my car or in my phone, but when I use the "Wait" feature, my phone gets stuck sending a single tone. So, through the car speakers it sounds like someone is holding down one of the number buttons. When I disconnect the bluetooth, the phone is still making the beep sound and I have to power down the phone to make it stop. No other bluetooth connection I've used with the same phone has done this to me.
So if you can successfully use that feature, you're doing better than me!
Razr V3C is my phone, btw. And F#@! Verizon for not letting me BT transfer my phonebook!!
2006 Barcelona Red Metallic - a.k.a. "The Professor" :: Accessories/Mods :: BT Tech Stiffening Plate - Engine Block Heater - OEM EV button - OEM Mud guards - Rear Bumper Protector :: Near-future :: ScangaugeII
Ichabod is offline
Old 09-19-2007, 09:05 PM   #7
burns_fisher
Burns
burns_fisher's Avatar
Package: #8
<div class='quotetop'>QUOTE(Ichabod @ Sep 17 2007, 02:49 PM) [snapback]513834[/snapback]</div>
Hmmm. Without being in the car...my recollection is that I programmed a W in. It dials the number up to the w. When the phone answers and it switches over to the "talk mode" there is a button on the right of the screen that allows you to dial some more. When you hit that, the dial screen appears with the numbers after the w initially there, so if you now push "send" they get sent. I was pretty sure I had done this while moving, but I could be wrong. I just use it for voicemail. My phone typically notifies me of VM only after I've started moving. (P.S. It would have been nice if there were a bluetooth service/protocol to notify you of VM and text, and to read text messages. And/or if the Prius supported said services).
Burns
2007 Super White
2002 Green
burns_fisher is offline
Old 09-20-2007, 11:48 AM   #8
Winston
Winston's Avatar
I tried to use the pause feature yesterday evening. I programmed a number that had a pause in it, but the phone would never send the tones after the pause. Even after waiting for a minute. Anyone able to get the pause feature to work?
Winston is offline
"pause" and "wait" functions in dialing nmw123 Audio and Electronics 6 03-21-2008 11:33 AM
Top 100 Toxic Polluters in U.S.<img alt="" src="chrome://easygestures/skin/xLink.png" style="border: 0px none ; margin: 0px; padding: 0px; display: in ghostofjk Environmental Discussion 0 05-12-2006 10:09 PM
