| Prius Technical Discussion This is a discussion on That darn annoying BEEP within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Anyone ever get annoyed by the BEEP every time you press a button surrounding the MFD in the Prius? I ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Anyone ever get annoyed by the BEEP every time you press a button surrounding the MFD in the Prius? I hate it. I want to change the fan speed while using the fan only, not the Auto A/C. So I press Climate (beep!) then the desired fan speed (another beep!) I wish this could be disabled. Anyone know if there is a way? |
| Resident Witch Join Date: May 2007 Location: Grays Harbor, WA, USA
My Car: 2007 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 52 | I hear you! The beeping is a bit annoying. Yes, I KNOW I pushed the button, I reached over and DID IT. I hope someone has an answer to this one |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Rae Vynn @ Sep 12 2007, 09:10 PM) [snapback]511730[/snapback]</div> Quote:
| Senior Member Join Date: Jan 2006 Location: Chatsworth, CA
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I honestly never noticed it. I guess I concentrate on driving too much. If the beep bothers you maybe the radio isn't loud enough. |
| The annoying "backing up" beep.... | AOV | Audio and Electronics | 22 | 04-13-2008 08:57 PM |
| Disabling reverse beep/seatbelt beep on an 06' | Paradox | Prius Main Forum | 31 | 05-30-2006 10:53 PM |
| annoying seat belt beep | kente777 | Prius Main Forum | 5 | 11-23-2005 01:41 PM |
| Annoying Reverse beep 2005 Model | billysimmerson | Prius Main Forum | 4 | 06-01-2005 12:49 PM |
| Disabling the reverse beep (and seatbelt beep) | dougkm | Prius Main Forum | 1 | 12-01-2003 07:42 AM |
