| Prius Technical Discussion This is a discussion on What do I need to activate software on my 2007 Prius within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(bwilson4web @ Sep 26 2007, 01:55 PM) [snapback]517986[/snapback]</div> First understand what you've got; then perform experiments to see the ... |
| | #11 | |
| Member Join Date: Sep 2007
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(bwilson4web @ Sep 26 2007, 01:55 PM) [snapback]517986[/snapback]</div> Quote:
| | #12 | |
| High Fiber Member Join Date: Jun 2005 Location: South OC So Cal & the Flathead Valley MT
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | <div class='quotetop'>QUOTE(bwilson4web @ Sep 26 2007, 01:44 PM) [snapback]517981[/snapback]</div> Quote:
| | #13 | |
| Senior Member Join Date: Mar 2007 Location: Tulsa, OK
My Car: 2007 Prius Package: #1 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | <div class='quotetop'>QUOTE(bwilson4web @ Sep 26 2007, 12:44 PM) [snapback]517981[/snapback]</div> Quote:
I don't understand why the cruise control has to forget your settings after you go too slow or stop. The one on my 05 Avalon remembers where it was even after a complete stop. Just start up and gain a little speed, then push it up to the resume position and the car goes back to the speed it was before you stopped. When I first got my Prius, I thought that the cruise control was broken till I figured it out that it didn't work like the one in the Avalon. | |
| | #14 | |
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 7 | <div class='quotetop'>QUOTE(Anai @ Sep 28 2007, 08:56 AM) [snapback]518948[/snapback]</div> Quote:
Access to the Prius source code and programming interfaces is at best a corporate trade secret. However, all of the 'inputs' and 'outputs' are mapped by the maintenance documentation including the wiring diagrams. So instead of trying to break-in to a closed system, think "shell" and deal directly with the inputs and outputs. For example, my temperature hack: http://hiwaay.net/~bzwilson/prius/pri_temp.html I wanted my 03 Prius to have similar, fuel efficiency to the Japanese and European Prius. My first experiments used a diode, pot and switch to test what happens when the thermistor value is 'adjusted.' If the ICE is below 40C, the engine will choke and die. But at 40C and above, I can trick it into 70C and instantly go into hybrid operation and save 3 minutes of ICE warm-up. I also had to make sure the 'bias' backed out after reaching 80C or the engine would report overheating. But I wasn't happy with the analog approach because it wasn't as precise as I wanted and didn't record any history. Now I use an MSP430 microcontroller to handle the thermistor hack. This lets me control all aspects with software that I can change at will. After a few tweaks, it worked quite nicely. Now I'm looking at making a bunch of them for an after-market offering. Bob Wilson | |
| | #15 | |
| Senior Member Join Date: Aug 2005 Location: CA
My Car: 2007 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Anai @ Sep 25 2007, 07:18 PM) [snapback]517717[/snapback]</div> Quote:
| | #16 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Rest @ Sep 29 2007, 01:35 PM) [snapback]519083[/snapback]</div> Quote:
| | #17 | ||
| Shire rat Join Date: Feb 2007 Location: Dallas
My Car: 2007 Prius Package: #5 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | <div class='quotetop'>QUOTE(bwilson4web @ Sep 29 2007, 08:16 AM) [snapback]518978[/snapback]</div> Quote:
<div class='quotetop'>QUOTE(Anai @ Oct 6 2007, 01:40 AM) [snapback]522108[/snapback]</div> Quote:
| | #18 | |
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 7 | <div class='quotetop'>QUOTE(patrickindallas @ Oct 6 2007, 03:08 AM) [snapback]522120[/snapback]</div> Quote:
Measuring the effect requires an exhaust tester and a dynometer. Doable, it would be a little pricey. Bob Wilson | |
| Any Prius software updates or hacks? | BoHenriksson | Prius Technical Discussion | 5 | 08-30-2007 09:35 PM |
| 2007 Prius software problems | dionmonge | Prius Main Forum | 20 | 01-26-2007 11:09 AM |
| Activate anti-theft | kente777 | Prius Main Forum | 1 | 01-05-2006 07:44 PM |
| Scan tool activate alarm on 06? | Jeffreywho | Prius Main Forum | 0 | 12-18-2005 11:22 AM |
| Software bug with Prius | jaguaraja | Prius Main Forum | 5 | 01-01-2005 06:00 PM |
