| Prius Technical Discussion This is a discussion on Oil Change Plug Gasket within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Im going to be changing my oil next week so I went over to autozone tonight get supplies. I bought ... |
| Senior Member Join Date: Jul 2007 Location: White Plains, NY
My Car: 2007 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Im going to be changing my oil next week so I went over to autozone tonight get supplies. I bought everything but the plug gasket. This doesnt come with the filter does it? I got a mobil 1 filter. I asked the guy there and he didnt know. Also told me the car might be too new. This didnt make sense to me but anyways the question is where do you guys buy your plug gaskets? |
| Senior Member Join Date: Aug 2005 Location: CA
My Car: 2007 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Are you talking about the oil drain bolt crush washer? If so, then no it doesn't come with an oil filter. Since it doesn't have anything to do with the oil filter, it wouldn't come with it. You can get them online or at a Toyota stealership. I have reused my crush washer 3 times so far. Just don't over tighten it and it will be fine. |
My Car: 2007 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Rest @ Nov 13 2007, 06:11 PM) [snapback]539109[/snapback]</div> Quote:
I am talking about the little washer thing that john shows next to the filter in his steps to change the oil. how much is this item too? | |
| Resident Witch Join Date: May 2007 Location: Grays Harbor, WA, USA
My Car: 2007 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 43 | We got ours at a local auto store, about 3 for, um, $2, I think, or less. They do come in different sizes. Check the manual, or do what Dear Hubbs did, pull the oil plug, and while the car is draining, drive a different car to the local auto store, and ask for crush washers to fit THIS ONE RIGHT HERE. |
My Car: 2007 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Last time I bought oil filters at the dealer (3 at a time), they threw one of those In for free! It's really not necessary to replace the crush washer everytime. I changed oil in my previous 300ZX for 13 years and 320,000 miles, and changed that washer once. JMHO |
My Car: 2007 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(9G-man @ Nov 14 2007, 02:25 AM) [snapback]539323[/snapback]</div> Quote:
I guess I dont see the point in not replacing it if its only 25 cents, why dont you? | |
| Senior Member Join Date: May 2006 Location: Cincinnati, OH
My Car: 2006 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(SureValla @ Nov 14 2007, 06:26 AM) [snapback]539355[/snapback]</div> Quote:
I might be concerned about the precise 'crushability' of a non-OEM washer. It's quite possible that an auto parts store is providing a hard, regular metal washer that isn't designed to compress as readily as the soft aluminum of the OEM drain plug 'gasket'. A cheap, hard, non-crush, metal washer would most likely result in a leaking drain plug. | |
My Car: 2007 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(rudiger @ Nov 14 2007, 04:35 AM) [snapback]539361[/snapback]</div> Quote:
My Car: 2007 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(SureValla @ Nov 14 2007, 08:26 AM) [snapback]539355[/snapback]</div> Quote:
Thank me for that later. My humble opinions are rhetorical. But, if you really want to know..... for the very reason you are having to inquire about it online...Finding one in the right size is not difficult, but not readily effortless either. And because in my experience only once was there a need to, and I'm wlling to bet I've changed the the oil in my cars 200 times. JMHO. It's like a valve stem cap, or gas-cap gasket, and cotter-pins, they are all dirt-cheap and should be replaced over time, but most often who really does it? | |
| Oil drain plug gasket (washer) question | rudiger | Care, Maintenance and Troubleshooting | 4 | 11-03-2007 10:47 AM |
| missing drain plug gasket | ACORNBLUES | Care, Maintenance and Troubleshooting | 13 | 09-26-2007 06:09 PM |
| motor oil on air filter gasket seal. Problems? | hockeymulder | Care, Maintenance and Troubleshooting | 4 | 01-15-2007 08:47 PM |
| Gasket for Oil drain plug | dzitlow | Care, Maintenance and Troubleshooting | 19 | 02-27-2005 01:49 PM |
| Oil Drain Plug Gasket | berryman | Care, Maintenance and Troubleshooting | 1 | 11-06-2004 06:26 PM |
