Prius Technical Discussion This is a discussion on Engine tries to stop, but won't, and cycles within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(qbee42 @ Nov 28 2007, 06:02 AM) [snapback]545162[/snapback]</div> It's not a problem. I explained it once in this thread, ...
Old 11-28-2007, 07:01 PM   #11
tank_3
It's not a problem. I explained it once in this thread, but here it goes again: When the SOC becomes too high, the Prius will spin the ICE without gas just to burn off the extra charge. You typically see this at the bottom of a long hill, when you come to a stop. The ICE will be off, then come on and race, then go off, then come on and race again. The cycle continues until the SOC is at an acceptable level. The engine is not really running, it's just being used as a load to waste energy.
Thanks. It is good to be reassured.
tank_3 is offline
Synchonized Cycles as a Driver of Climate Change TimBikes Environmental Discussion 10 10-31-2007 02:13 AM
Engine keeps starting and shutting down during traffic light stop aktam Care, Maintenance and Troubleshooting 5 12-27-2006 01:48 PM
Lithium-ion batteries: 15,000 deep cycles, 40 years life clett Prius and Hybrid News 15 10-28-2006 09:29 PM
"Engine Start Stop" vs. "Power" Buttons paulisme Prius Main Forum 2 04-21-2004 08:04 PM
Engine Run on at Stop rwcmjack Care, Maintenance and Troubleshooting 0 12-31-1969 07:00 PM
