| Prius Technical Discussion This is a discussion on Why does my 08 Prius use regenerative braking, even when the brake is not pressed ? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; hi ! I have a 08' prius.. I just noticed that on when I take the foot off the gas, ... |
| Junior Member Join Date: Oct 2007 Location: San Diego, CA
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | hi ! I have a 08' prius.. I just noticed that on when I take the foot off the gas, the regenerative braking immediately starts, and I can see the battery charge, in the "power flow" display. When going downhill, I can put the Car into 'N' from 'D' and I can immediately feel the difference of not having the regenerative breaking. my Highway commute mostly consists of gentle ups and downs' and I would like the car to ideally coast downhill, and engage the ICE only on the uphill.. But it doesn't work this way mainly because of the regenerative breaking, and I end up loosing mpg's as I have to use the gas pedal downhill too.. Does anyone have a way to get around this, other than using 'N' ? Also do other other prius's (07 and earlier) behave identically ? TIA |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | It does this to make the car handle in a way consistent with ordinary cars. The slight regen action simulates engine drag. To avoid this, slightly feather the accelerator peddle. Tom |
My Car: 2007 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The Toyota engineers have built in several things to make us more comfortable with the car. To make it feel like a "normal" automatic transmission equipped car. 1. Simulated engine drag when coasting. As stated above, just feather the accelerator pedal a bit to shut this off. This takes practice. 2. Transmission "creep" when you release the brake pedal when stopped. There's a third one but I can't think of it right now. It'll come to me the minute I log off. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Thanks for the reply.. "Feathering" the throttle is pretty tough.. Seems to me by making this a feature, there is a substantial drop in mpg's, especially on S.California freeways.. Have been experimenting on downslopes, by waiting for the mpg to hit a 100, and then moving into "N" mode.. I am now consistently averaging well over 50 on freeway drives. whereas earlier I used to get less than 50 mpgs.. Will keep the group posted if I see a big jump in mpg's by the end of my next fill up. Another funny thing, I noticed on a steep downslope, if I put it into "N" mode, and then back to "D", the regenerative breaking doesn't come on.. |
My Car: 2005 Prius Package: #4 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 15 | Like stated above, your best bet is to learn how to lightly apply the gas pedal to kick the system out of regen mode. There are write-ups on how to do this. Maybe do a search for "warp stealth". When traveling downhill or approaching off-ramps this technique is very handy. You will need to learn how to work with the gas pedal anyway to get maximum milage so you might as well practice now. Here are some links for ya. Coasting in neutral Last edited by F8L; 12-05-2007 at 12:59 AM. |
My Car: 2004 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 12 | If you drive at freeway speeds in neutral you can damage the smaller of the 2 electric motors in your transmission because having the Prius in neutral isn't really neutral but it just cuts electricity flow in the hybrid synergy drive (HSD) transmission. At higher speeds the HSD causes the petrol engine (ICE) to spin over, if this isn't allowed to happen the smaller electric motor (MG1) can overspeed possibly causing damage. The best way to prevent the over-run regenerative braking is to feather the throttle, easy once practiced and after all when your driving what else do you have to do?
__________________ All the warranty I need. And for thrills -> ![]() Still averaging 4.4L/100km across town 2004 silver base model Prius Shark fin, genuine mudflaps, colour matched side mouldings, rear bumper scuff guard, sheepskin seats, BT Plate. I love it! Last edited by patsparks; 12-05-2007 at 02:32 PM. Reason: missing letter |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Quote:
I suspect what you are trying to learn are the same high-mileage techniques used in any car: try to keep a steady speed, avoid slowing down, anticipate, accelerate briskly to speed, etc. In that respect, there is nothing unusual about driving a Prius, except for the constant feedback from the MFD. Tom
__________________ Black 2006 package #7 Northern Michigan | |
| Senior Member Join Date: Mar 2005 Location: Colorado
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
I've got 55,000 miles on my car and I've been coasting down hills at high speeds in neutral whenever I have the chance. No problems yet. | |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 21 | Quote:
If you go into neutral with the ICE turning it will continue to run...since it's running it will prevent MG1 from over spinning at any speed. The engineers did do a lot to prevent us from damaging the car...but you can always build a better moron! | |
