| Prius Technical Discussion This is a discussion on CR says 60 MPH = 3495 RPM within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Originally Posted by ceric Gee, who am I gonna believe, CR or MotorTrend? CR.... |
| | #23 | |
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 7 | Quote:
Bob Wilson | |
| | #24 | ||
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
There is nothing hard about having a car without a tach. And if you are planning on trying to optimize your mileage, then there is aftermarket equipment you can purchase for the Prius to assist you. So if you insist on having a tach, you can get one for the Prius. Last edited by Danny Hamilton; 12-11-2007 at 12:46 PM. | ||
| | #25 | |
| Junior Member Join Date: Aug 2007 Location: Los Angeles, CA
My Car: Other Non-Hybrid Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
Here are the specs they publish for some other CVT cars: Toyota Camry Hybrid: RPM@60MPH=1700 Honda Civic Hybrid: RPM@60MPH=1810 Nissan Altima 4-cyl: RPM@60MPH=1940 Nissan Altima V6: RPM@60MPH=1945 Nissan Versa: RPM@60MPH=2050 So clearly, several cars with no fixed gearing can be put through their test and come out with an accurate ICE number. Even if there is some fluctuation in the ICE RPM during the test, they must have some way of averaging it so that they can publish something relevant. Now look at the Prius number: Toyota Prius: RPM@60MPH=3495 Holy Cow!!! Clearly it must be the MG2 number, not the ICE number. And they need to include of explanation or else, better still, just give us the ICE number like they do on all the other CVT cars they test. | |
| | #26 |
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I haven't read the CR article, but in this thread there is just too much missing information. What was the state of charge of the HV battery? What was the engine coolant temp? What stage of operation was the Prius in? Had it most recently accelerated or decelerated? I agree that it sounds like MG2, but with so much information unknown or assumed, the number is rather meaningless. |
| | #27 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | lets remember here that the ICE doesn't directly power the vehicle to wit the fact that it will go into stealth and still accelerate. MG2 moves the car as it drives the chain that turns the gear reduction gear set. Plenty of pix here on PC to show that and the final drive reduction is stated as 4.113 to 1 so 3495 /4.113= wheel speed of 849.7 RPM times the circumfrence of the tire / feet = well you get the rest of the equation. The underlying fact is the ICE isn't directly connected to the wheels so ICE RPM isn't worth stating. CR looses again. Honda's IMA has the ICE directly connected to the wheels.
__________________ You can quote me on this, People who drive vehicles that idle at a traffic light, are idiots. mine 2k3 avg. 5.36 for 46,915Km Best tank 4.4L per 100K 64.2 Imperial 53.4 U.S. gallon, MiniScanner, SilverStars, block heater, winter lips, in as of Oct 15, out on April 25. In again on Sept. 21st. her's 2k4 "B" avg. 6.01 for 42,317 Km Best tank 4.02L per 100K, CAN-view with OBD11 module and flashloader, SilverStars, 06 Chrome grill bar, Michelin HydroEdge, upper and lower grill blocker,upper out as of April 7, lower out on April 28. In again on Sept 21st. |
