Prius Technical Discussion This is a discussion on Driving with the headlights always on within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I am a new owner of a 2008 Prius package 2, non HID lights. I've always driven with my head ...
LinkBack (1) Thread Tools
Old 04-01-2008, 09:56 AM   1 links from elsewhere to this Post. Click to view. #1
rep308
Default Driving with the headlights always on
I am a new owner of a 2008 Prius package 2, non HID lights. I've always driven with my head lights on all the time as a safety precaution and all that it has caused me is to buy new head lights more often. Should I be concerned about doing this in my new Prius? I just think it is safer to be seen.
rep308 is offline
Old 04-01-2008, 10:00 AM   #2
holy_crap
holy_crap's Avatar
Default Re: Driving with the head lights always on
I have been driving with my headlights on too. I like the fact that when you turn off the car and open the driver's door the lights automatically shut off. I am looking into a DRL solution for my yellow turn signals instead of my headlights.
holy_crap is offline
Old 04-01-2008, 10:18 AM   #3
jayman
Non HID all you will end up doing is replacing the halogen bulbs more often. That's DIY although a bit of a hassle
For HID Prius owners, do NOT run the headlights all the time. The bulbs/igniters are *very* expensive to replace. Cars and SUV's here with HID, such as Range Rover, Mercedes, Lexus, all use dedicated DRL bulbs
jayman is offline
Old 04-01-2008, 11:00 AM   #4
seasalsa
seasalsa's Avatar
Send a message via AIM to seasalsa
I ave driven with my lights on since day one with my Prius.
I replaced the left bulb at about 20k and the right at about 25k. I used regular bulbs rather than Silver stars.
I now have about 70k on my car with no further outages.
Changing the bulbs can be a hassle as mentioned above: primarily because you have to feel what you are doing rather than being able to see. I found that a small mirror helped some.
seasalsa is offline
Old 04-01-2008, 11:02 AM   #5
JimboK
One owner, low mileage
JimboK's Avatar
The standard headlights draw somewhere in neighborhood of 5 amps. (Not sure whether HIDs draw more.) That's a small drain on the battery, relatively speaking, but it will require a wee bit of engine power to replenish it. Though the actual impact on fuel economy is almost certainly insignificant, it is in part for that reason that some who are obsessed with FE choose not to run headlights in the day. Won't say who those someones are.
JimboK is offline
Old 04-01-2008, 11:05 AM   #6
Friends: 5
Plus the photons exiting the headlamps create a small amount of thrust in an undesirable direction (just for those really obsessing about mileage).
Old 04-01-2008, 11:16 AM   #7
hyo silver
and awaaay!
hyo silver's Avatar
Friends: 21
Yeah, but don't the red photons out the back create even more thrust? Hmmm...that means the brakes aren't as effective as they could be...
hyo silver is offline
Old 04-01-2008, 11:33 AM   #8
Boo
Boola Boola Member
Boo's Avatar
Friends: 11
Hi SeaSalsa,
That's good to know about the expected longevity of the OEM halogen bulbs when they're constantly on (20-25k).
So what replacement bulbs did you use that have so far given you 40-45k and are still going strong?
Is the light at least as bright as the OEM's?
Hi rep308,
FYI, when your OEM bulbs burn out, I think you should consider not replacing them with OEM bulbs from your Toyota dealer. I hear that Toyota charges $45-$50 for one OEM halogen bulb (plus labor). You can do better in all regards going outside OEM halogens.
Best regards, Tom
Boo is offline
Old 04-01-2008, 11:50 AM   #9
Hemi4Prius
Geek Girl
Hemi4Prius's Avatar
So the general consensus here is *not* to leave the HID headlights on all the time, correct? I have the HIDs and I don't want to replace them before I have to. Thanks for the advice!! I've been leaving them on all the time, but I think now I'll only use them at night.
Hemi4Prius is offline
Old 04-01-2008, 12:51 PM   #10
Boo
Boola Boola Member
Boo's Avatar
Friends: 11
Yes, I think that's true. And in part because of the high replacement cost of the OEM HID bulbs (I hear Toyota dealers charge around $350 for each bulb alone -- installation is extra).
But I believe I've read elsewhere on PriusChat about some members modifying their OEM halogen fog lights so that they can turn them on independently of the HIDs; and by so doing, they're able to use the fog lights as daytime running lights, as well as having better performance of the fog lights in fog (no reflective glare-back from the HIDs).
Boo is offline
LinkBack to this Thread: http://priuschat.com/forums/prius-technical-discussion/44966-driving-headlights-always.html
Toyota Prius Online Community with News, Forums, & Research - PriusChat This thread Refback 04-08-2008 04:45 PM
