| Prius Technical Discussion This is a discussion on 142MPG? I need some help here. within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I doubt the pump accuracy changes much due to flow rate. The meter is a displacement type, and the fuel ... |
#31 |
My Car: 2007 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I doubt the pump accuracy changes much due to flow rate. The meter is a displacement type, and the fuel doesn't bubble until it drops out of the nossle (unless the underground tank is almost empty). The main reason for refilling slowly is to get a bit more fuel in before shutoff, and to avoid a lot of bubbles in the tank that have to "bleed off", possibly causing a burp out. Always remove the nossle slowly, just in case. I even depress the nossle down to create a gap in the seal at the top to bleed off any pressure that -may- spit out fuel. If you find yourself in this situation (fuel trying to spit out), be patient. The pressure can be bled off slowly without much fuel loss. Pearl has only spit on me twice, both times due to a faulty filler shutoff. The -second time- (yes, I learn from my experiences) I avoided fuel spillage by being patient. Be aware you can't use the last gallon or so of fuel in the tank. Unless you are shaking the tank. There is a cavity in the tank system where the fuel pump resides (for cooling and to ensure it is always pumping fuel and not air). Contaminants also settle out there (below the pump). Also note, it -may- be possible to overheat the fuel pump by running out of fuel, though the fuel pump in the Prius will shut off if the engine dies, so it is a little less possible to burn out the fuel pump in a Prius than in other cars. This cavity also causes what some owners who have run out report - you have to put in at least two gallons to get the thing running again. Running out of fuel in a Prius is not a "good thing" (tm). Better to avoid that situation. I fill up at around 1/2 tank if in the city. On the highway I fill up at 1/4 tank if possible. Besides, it's fun to fill up the Prius. Perhaps because my previous vehicle was a Nissan Pathfinder (the anti-Prius), which took 80 litres of Premium! Around $100!! Pearl usually takes $20 to $30 of regular.
| | #32 |
| Senior Member Join Date: Oct 2007 Location: Bolton,CT
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Hey, all, I always fill up when I get to only 2 pips remain'g (once it got down to one pip before I could find an open station---I didn't like that feel'g). I have an '05 that automatically resets BOTH the MPG & miles-between-fillups on the screen ('04's do that too). In the winter I go between 350 & 380 miles before the 2 pips. In the summer it goes up to between 400 & 430 miles before getting down to the 2 pips. I think on the '06 though '08 models only the screen miles get automatically reset at fillup because the MPG is left alone each time to maintain a "lifetime average MPG" (a throwback to the way the early adopters preferred it in their '01 through '03 models). My point is this : either fill up at 2 pips all the time (to be safe) or if you're going to do the calculations of MPG times the # of useable gallons you feel comfortable with (because of the bladder, more in the summer & less in the winter), then give up on your lifetime MPG (keep your own records on a pc spreadsheet) & do a manual reset (of the MPG) at every fill'g. My reason'g is this : on an '06 through '08 car (lifetime MPG) with many miles on it, the lifetime average will probably be pretty high. So unless you reset your MPG at every fill'g, one tank that gets affected by an extreme drop in temp or new hilly terrain won't show too much of a drop on a lifetime average display but will certainly reduce the # of miles you can safely travel without running out of gas. Let me use an example. Let's say your lifetime average indicates 52 MPG (lucky you) & you don't ever reset your MPG's on the screen. Let's also say that it's warm weather, but you haven't really noticed that on this tank you've been doing a lot more stop & go (read that "warm up") cycles & you've also been in some hilly terrain. If you HAD reset at the start of this tank, you might find your MPG for THIS tank to be only 40 MPG. If you HAVEN'T done a reset then this one "bad" tank might only bring your lifetime MPG down from the 52 to an indicated 50 MPG. That would mean a difference or "error" of 10 MPG [indicated 50, LIFETIME minus REAL 40, on this tank only (WITH the reset)], times 10 useable gallons (you're think'g the 10 gals because it's warm weather, remember). These calculations would lead to 100 miles less of useable travel than you think you safely have. That's why I'm glad my 2005 automatically resets BOTH MPG & MILES at each fillup. I just look at my true MPG (from the car's own calculations of fuel actually put through the injectors) & I can pull out my logbook of how many gallons I added at last fillup & multiply those gallons times my MPG & fillup before my miles on screen reaches my calculated "safe" miles. It's fairly simple to do but mostly I just refill at 2 pips & it's within the ranges I stated above in the 1st paragraph. I've never run out of gas yet & I don't intend to. Also, you should go to the main forum & find the thread entitled "When do you refill?". It's a poll, so vote, view the results, & then read all the comments there. See other like topics or threads (usually found way down at the very bottom of the page). Ken (in Bolton,Ct) Last edited by Ct. Ken V; 04-05-2008 at 03:41 AM. |
| | #33 |
| Senior Member Join Date: Feb 2008 Location: hollywood
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 13 | THIS brings up an interesting point. my FIRST pip disappears at about 60 miles driven. My computer says my mileage is about 46-47 mpg. is this normal? i was not too concerned about this until i read this thread. thanks for any input, |
| | #34 | |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 28 | Quote:
Your car is "normal", given the variability caused by the bladder, production differences etc. | |
| | #35 | |
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Quote:
after 4 years, i can tell you, if you are stopping at the first click (or near it. you should always have an idea as to how much to put in based on your MFD display assuming you manually reset after every fillup) you will be in the normal range. now there are too many people who want the 11.9 gallons in the tank. well, lets face it. we are all basing this want and need on previous vehicles we have owned. once again, american car manufacturers have come back to haunt us. i read many stories about disappointed Prius owners relating stories about how their gm had a 20 gallon tank and they were able to put 20+ gallons in it because of the "reserve" all the while discounting advances in technology on Toyota's part, the lack of quality control on gm's part, etc. you cant have your cake and eat it too. Toyota's biggest mistake was reporting the tank size in the first place. their 2nd biggest mistake was assuming that we would be happy with a vehicle that had essentially the same usable range as our previous vehicle. (ya thats right, even when we have only 9-10 gallons of usable gas that still gets us the same distance as our previous car) now maybe they should use a tool like my GPS system, it has a digital gauge for miles to turn, miles left in total trip, etc... when i am 1000 feet away from my turn, an analog gauge pops up so i can see the rate i am approaching the turn, makes it nearly impossible to miss a turn. now if Toyota were to incorporate something similar in their gas tank, maybe that will prevent people from ignoring the warnings to get gas. just have a mini analog gauge pop up when the last bar starts to blink...
__________________ My 2006: Last tank 463.1 miles @49.2 pump (49.4 computer) 4.22 cpm winter mpg 50.70 summer mpg 54.59 lifetime: 33,038.3 miles 52.79 mpg pump (54.04 mpg computer) 5.74 cpm My 2007 Zenn Driven 5849 miles, 2.00 cpm/ 105 mpg (at $2.05/gal), 4.04 miles/ Kwh Savings over my Prius $300.79 The Corolla...567.79 The REAL SAVINGS from not driving Corolla 657.39 +Prius= 958.18 (excludes maintenance costs...would be unfair to ICE vehicles) My Plate: DUALPWR (Dual Power) | |
| | #37 |
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | another quick comment...the filler tube is exactly that, a tube used to fill the tank... its not a "storage" tube. so if you see gas in the tube, you are in the process of destroying your fuel storage system. |
| | #38 |
| Member Join Date: Mar 2008 Location: Camarillo, California USA
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | On a recent trip I noticed the gas gauge didn't drop one pip until I had driven over 180 miles after filling the tank. I think it's normal for the Prius. jd |
| | #39 | |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | Quote:
Tom | |
| LinkBack to this Thread: http://priuschat.com/forums/prius-technical-discussion/44968-142mpg-i-need-some-help-here.html | ||||
| 142MPG? I need some help here. - Page 3 - PriusChat Forums | This thread | Refback | 04-04-2008 03:34 PM | |
