| Prius Technical Discussion This is a discussion on Longo Toyota tells me Prius overheating is *normal*!? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I can just imagine you sitting on the couch cutting out little paper "fan blades" with a beer in your ... |
| | #41 |
| Senior Member Join Date: May 2007 Location: SF Bay Area, California
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I can just imagine you sitting on the couch cutting out little paper "fan blades" with a beer in your hand. Yea, the "puller" to a "pusher" concept is a myth. I agree the fans are designed to work much better when installed the right way, but flipping it will not make it push air. |
| | #42 | |
My Car: 2004 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | Quote:
![]() Oi | |
| | #43 |
| nacreous lacquer Join Date: Mar 2004 Location: United States
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | NARFF!!! Glad to be of service, and thanks for th' chuckle :_> |
| | #44 |
My Car: 2004 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | Well, I finally got around to doing that little science experiment with my '84 Ford. It has a custom-made 5 row rad, a hub spacer, and a Flex-a-Lite heavy duty towing fan, similar to this one Flex-a-lite 7-Blade Flex Fan Even at idle, that fan really pulls air in. At 2,000 rpm it has a low roar to it Very easy to unbolt the shroud, undo the fan bolts, and flip the fan around. Around 4 mins later I had everything tightened down, hopped into the cab, hit the starter. Oh boy, what a weird noise. Sort of a whack-whack-whack noise. I checked the fan wasn't hitting anything, just the blades themselves were making that weird noise Airflow: there actually wasn't any that I could determine. Normally, at idle you can feel a *very* strong airflow out the fan over the motor. Nothing. So I aborted the science experiment before fan blades started to fly off, and put it back on properly. Wonder where that urban legend of turning a car fan into a pusher came from?
__________________ 2004 Toyota Prius "B", Tideland Pearl 2007 Toyota FJ Cruiser 5AT "C", Sun Fusion |
| UK advertising body tells Toyota to modify 'misleading' Prius TV advert | jiepsie | Prius and Hybrid News | 3 | 06-07-2007 07:28 AM |
| Longo Toyota (Los Angeles) | uclabruins | Prius Main Forum | 2 | 09-14-2006 03:14 PM |
| Longo Toyota | gnawl | Prius Main Forum | 11 | 12-04-2005 12:03 PM |
| LONGO Toyota, FEES!! | tixe | Dealers & Pricing | 9 | 10-09-2005 08:20 PM |
| Longo Toyota in El Monte - Class-A Service | macreative | Prius Main Forum | 2 | 10-31-2004 12:38 AM |
