| Prius Technical Discussion This is a discussion on Is turning off VSC bad for the transmission? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Hey there, just wondering if driving with the vsc off is in anyway detrimental to the planetary gearset? Sometimes under ... |
#1 |
| Junior Member Join Date: Jun 2008
My Car: 2004 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hey there, just wondering if driving with the vsc off is in anyway detrimental to the planetary gearset? Sometimes under heavy acceleration 1 tire tends to spin out of a corner. But i let off as soon as this occurs. i frequent the car on dirt roads and to the snow and in many cases need to turn it off in order to reach decent speeds. Anyone else do this alot? |
My Car: 2004 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 12 | Can it be turned off? Sorry I don't have VSC so I don't know. If you can turn it off you would still have traction control which is required to protect the motors in the hybrid system from over reving. |
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | Unless you have some sort of hack in mind, I don't believe you can turn the VSC off on the Prius. My GF's Avalon does allow you to turn VSC off; there is a button on the lower dash to defeat it. VSC is separate from TRAC; VSC is optional depending on which package your car is equipped with, but TRAC is built into the HSD system. To answer the original question, I don't believe it would be detrimental to the hybrid system to turn off VSC (if you could) because it is not included on all Prius. |
| ichorous liquor Join Date: Mar 2004 Location: United States
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | If you instead mean the anti-slip system (the thing that kills drive power when a wheel slips, which every Prius has) then you most definitely do not want to turn it off. That would allow the transmission to damage or destroy itself. |
| High Fiber Member Join Date: Jun 2005 Location: South OC So Cal & the Flathead Valley MT
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | Quote:
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | You can't turn either TRAC or VSC off on demand in the Prius. The simpliest solution is to put better Tires on for your driving environment....dirt or snow. |
My Car: 2004 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Not on demand. But a quick turn off and then the foot dance, and vsc turns off completely. Its quite fun actually, the prius tends to oversteer quite a bit in stock form. Shocking isnt it. It was for me. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | On my '05 Prius there was a hack to shut off the TRAC for emission control tests on a chassis dyno and I think it also shut off the ABS and VSC (if equipped). The hack should still be on this site among the real old posts. As stated above it would not be a good idea to drive the car with TRAC off because it helps protect the drive train. The Prius was simply not designed to be driven that way. My BMW on the other hand was and you can turn off the Traction Control or the Dynamic Stability Control independently with a switch for the track (or the street if you are foolish enough to want to). The only time I have had either of them off was when I got stuck in the snow last winter, it didn't help and I had to get a friend to pull me out with his Hybrid Camry, he still laughs about it.
__________________ former Prius owner, waiting for a G III present car BMW 3 series |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | get better tires... like mine.. and pump up the psi if you want to toss the car through corners... with the psi high the car simply slides... but still accelerates wait... no.. i eat your cake btw.. the prius has a really good weight balance.. with the battery over the wheel wheels.. it holds. oh.. and get a brace.. you pick where they come from.. just get them. it's still gets better mpg than your last car.
__________________ Silver 9 as of June 12th '04 (over 101k Miles now) Decals, Mud Flaps, BT Tech Rear Brace, coastaletech 2" receiver hitch, and 215/45/17 tires. Last edited by V8Cobrakid; 06-19-2008 at 07:24 PM. Reason: i can't spell... again... |
| LinkBack to this Thread: http://priuschat.com/forums/prius-technical-discussion/49358-turning-off-vsc-bad-transmission.html | ||||
| Prius Technical Discussion: Blogs, Photos, Videos and more on Technorati | This thread | Refback | 07-09-2008 09:34 PM | |
| ICE turning on and off | nosliw | Prius Technical Discussion | 11 | 03-30-2008 04:57 PM |
| Turning right to save gas. | Steamboatsig | Fuel Economy | 5 | 03-04-2008 07:09 AM |
| ICE keeps turning on during commute | philaprius | Fuel Economy | 9 | 11-29-2007 07:05 PM |
| Turning MFD OFF | rufaro | Prius Main Forum | 15 | 08-17-2006 10:56 PM |
| squeak while turning | murray1207 | Care, Maintenance and Troubleshooting | 5 | 11-10-2005 06:44 AM |
