| Prius Technical Discussion This is a discussion on Long Inclines And Battery Drain within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; One thing that might help a Prius in such conditions is running a K&N filter or similar set up--even if ... |
| battery, drain, inclines, long |
| | #21 |
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | One thing that might help a Prius in such conditions is running a K&N filter or similar set up--even if you wouldn't run them normally, they might make sense for high elevation operation. The engine is going to be able to do far less work at a given rpm so any reduction in pressure drop will mean more air into the engine (higher absolute pressure in the throttle body) and slightly more work than it could otherwise perform. What kills you at altitutude is that there is less pressure (partial pressure of oxygen) entering the engine per revolution. Additionally, I suppose it would help to shut off the AC before the start of the climb and throughout. That would conserve traction battery. |
| | #22 |
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 7 | With 4,500 miles, you probably still have:
Bob Wilson |
| 12V Aux Battery Drain - when off | boom27 | Care, Maintenance and Troubleshooting | 1 | 02-25-2008 10:33 PM |
| Battery Drain | Prianista | Prius Technical Discussion | 2 | 10-09-2007 12:43 AM |
| Battery Drain | skijapan | Prius Technical Discussion | 1 | 08-03-2006 02:11 AM |
| HV Battery Drain | Tideland Prius | Care, Maintenance and Troubleshooting | 2 | 04-30-2005 09:46 PM |
| Will my battery drain? | dbascher | Care, Maintenance and Troubleshooting | 17 | 11-11-2004 01:48 AM |
