Prius Technical Discussion This is a discussion on How to reset computer to factory settings ? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I've just sold my 2005 T Spirit and before the new owner collects it I'd like to clear all the ...
computer, factory, reset, settings
Old 06-24-2008, 04:36 PM   #1
SantaCruzDad
Default How to reset computer to factory settings ?
I've just sold my 2005 T Spirit and before the new owner collects it I'd like to clear all the map memories, clear the phone memories, restore default factory settings, etc. Is there any quick and easy way to do this ?
SantaCruzDad is offline
Old 06-25-2008, 03:42 AM   #2
Bill Merchant
absit invidia
Bill Merchant's Avatar
Nominated 6 Times in 1 Post
Friends: 46
Cool Re: How to reset computer to factory settings ?
Disconnect one side of the 12V battery (in the back, on the right side under a floor panel) and leave it disconnected for five minutes.
You can also erase all user settings in each system. May take a few minutes, but nothing to disconnect.
Bill Merchant is offline
Old 06-25-2008, 04:59 AM   #3
SantaCruzDad
Default Re: How to reset computer to factory settings ?
Many thanks Bill - I think I'll try the battery disconnection method as that should give a more thorough reset, I imagine.
Old 06-25-2008, 05:37 AM   #4
Flying White Dutchman
disconnecting the 12olt battery is not the way to go
i have my 12volt disconnected for longer then 5 min ( when it broke down ) and the phone numbers are still in the prius memory
you need to delete them by hand.
Old 06-25-2008, 05:54 AM   #5
SantaCruzDad
OK - thanks - I just went outside to try the battery method but couldn't easily find the 12V battery, so I went for the manual method and deleted the phone books, map memories etc by hand. It would have been nice to have been able to set all the various user settings to their factory defaults, but this is probably good enough.
Old 06-29-2008, 11:00 AM   #6
rigormortis
Package: #5 Touring
yeah i have had this verified. the prius phone book will definitely be retained when the 12 volt battery is disconnected.
you have to press the delete personal info button on the screen
the only thing that you lose when you disconnect the battery is the clock, the radio presets, and the automatic windows
and the settings to the back up alarm and seat belt alarms, and probably the trip meters, etc
even your garage door opener codes is retained when the battery is disconnected
rigormortis is online now
Old 06-29-2008, 07:07 PM   #7
Bill Merchant
absit invidia
Friends: 46
Thanks for the information, I stand corrected.
Changing some of the Factory default settings hannah Prius Main Forum 21 02-17-2008 03:21 AM
Prius Factory Default Settings? Three60guy Prius Technical Discussion 12 02-05-2008 10:47 AM
How To Change Factory Settings 07' contractor22 Prius Modifications 1 01-26-2008 04:19 PM
NAV settings reset after 10k service qbee42 Prius Main Forum 3 01-22-2007 06:40 PM
Can I reset the default AC settings? mastergunnera8 Prius Main Forum 6 07-10-2006 03:18 AM
