| Prius Technical Discussion This is a discussion on Instument lighte too dim... within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Got my 2008 Prius Monday and having a great time with the steep learning curve - one thing bothers me ... |
| dim..., instument, lighte |
| RtStuf Join Date: Aug 2007 Location: Prairie Village, Kansas
My Car: 2008 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | Got my 2008 Prius Monday and having a great time with the steep learning curve - one thing bothers me and I don't find a fix! The instrument panel, where the speedometer is, is very dim in the sunlight even with the brightness dial at max. Anyone know of a fix for this? |
| Member Join Date: Jan 2008 Location: Ithaca, NY
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
Zhe Wiz | |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | It shouldn't be too dim, even in direct sunlight. Perhaps your Prius has a problem. Are you wearing sunglasses? Some drivers report wearing sunglasses makes it hard for them to read the display. It appears to be related to the polarization. Tom |
| Senior Member Join Date: Mar 2007 Location: Tulsa, OK
My Car: 2007 Prius Package: #1 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | I feel for you. First, sunglasses do make it harder to read the display and polarized ones can almost make it disappear all together. Also you didn't say how old you are, but if you have cataracts it gets even worse. This isn't limited to just the Prius. My Avalon with it's fancy-smancy electro luminescent dials does the same thing in bright sunlight. |
| _ . _ . / _ _ . _ Join Date: Mar 2008 Location: Los Angeles
My Car: 2008 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Make sure your headlights are not on. If they are, it will dim the display and dim down the MFD. I went through this little learning curve when I got my baby in March!!! Enjoy the toy!! 73 de Pat KK6PD |
