Prius Technical Discussion This is a discussion on A couple of warning lights are on... within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I have a '04 and lately a few warning lights have been on: 1. Maintenance light: what symptoms will cause ...
couple, lights, on..., warning
Old 06-27-2008, 03:13 PM   #1
saelee39
Default A couple of warning lights are on...
1. Maintenance light: what symptoms will cause this light to come on? And how do I reset it?
2. Exclamation mark light, both the one with a circle and the triangle around it... I think this has to do with the Hybrid system and what can this be?
3. On the MFD, when I turn off the screen, there is a shape of a car on the upperleft... was wondering what this is also...
Thank you..
saelee39 is offline
Old 06-27-2008, 03:33 PM   #2
subarutoo
subarutoo's Avatar
Default Re: A couple of warning lights are on...
Don't they have dealers where you live? The only drive I would do with those lights would be to the service tech, and then only of a tow truck was not available. Maint. Light means its time for an oil change. Its easy to reset...lots of posts here on that, or read your manual ... no big deal. Exclamation light doesn't sound like a good thing. Not sure what the MFD is showing you. I have an 06, and my screen only shows the little green leaf cars as a result of energy stored back to the batteries. Go talk to the dealer.
Chatsworth, CA
06 Prius, White, Option 6, Visual Garage Shark Fin Antenna, BT Chassis Plate
NO trim rings, Scangauge II.
Other cars: '96 Subaru Outback, '00 Subaru Impreza RS
subarutoo is offline
Old 06-28-2008, 01:21 AM   #3
Bob64
Sapphire of the Blue Sky
Bob64's Avatar
Can you post a picture of the lights?
Bob64 is offline
Old 06-29-2008, 11:16 AM   #4
richard schumacher
ichorous liquor
You really need to read the owner's manual. If you did not receive the Owner's Manual and the Scheduled Maintenance Guide when you got the car, buy them from Toyota (online or at a dealer). In this case it sounds like a visit to a dealer is needed.
richard schumacher is offline
Old 06-29-2008, 04:40 PM   #5
northwichita
Engine code(s) were set. Could be lots of things, I had mine read at a local auto parts store for free. I recommend buying a scan gauge to read this with CAN readability. A scangauge II is really nice.
northwichita is offline
Warning Lights hopemeadow Prius Technical Discussion 2 03-19-2007 05:28 PM
Warning Lights! Help! Leslie Prius Technical Discussion 7 06-23-2006 12:09 AM
Warning Lights Houston Knowledge Base Articles Discussion 4 08-11-2005 09:39 AM
Warning Lights RickA Care, Maintenance and Troubleshooting 19 08-11-2004 07:19 AM
Warning Lights adrianlei Care, Maintenance and Troubleshooting 2 07-11-2004 03:24 PM
