| Prius Technical Discussion This is a discussion on Altitude Braking within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I recently went to Flagstaff, AZ elevation approx 7000 feet. When there my brakes made a squeeking noise when I ... |
| altitude, braking |
#1 |
| Junior Member Join Date: Jul 2008 Location: Arizona
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I recently went to Flagstaff, AZ elevation approx 7000 feet. When there my brakes made a squeeking noise when I depressed the pedal. Not from the pads but from the system. Also after I turned the car off the pressure release/equalizing noise was different than the norm as well. After i returned to Phoenix and lower altitude the noise stopped. Has anyone else had this happen at higher than the normal altitude or know of a reason this may occur. |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | It shouldn't be related to altitude. The brake system is sealed, so the ambient pressure is not an issue unless you are on the moon or the bottom of the ocean. I suspect it was coincidence. Tom |
My Car: 2007 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The squeaking noise when you apply the brakes is from the regeneration. Perhaps it's too noisy in Phoenix for you to hear? The noise you heard when you shut the car off was the fuel tank pressure release (through the carbon canister of course). It goes on for quite a long time (heard Pearl make this noise yesterday and waited for it to stop, and it was a long wait A change in ambient temp and pressure can make a lot of difference on how the cars systems work and what noises they make/how loud they are. |
| Senior Member Join Date: Oct 2005 Location: Northampton, MA, USA
My Car: 2005 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
I second (third?) the thought that there's no reason to have altitude-based differences. Perhaps David is right that it's too loud in Phoenix to hear it. | |
| Junior Member Join Date: Feb 2008 Location: Tucson, AZ
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Interesting ... I was in Flagstaff this past weekend also, and experienced something similar. I drove up on Friday evening, and Saturday morning noticed a strange squeak/chirp when I first depressed the brake pedal that sounded like it came from under the center console. I could reproduce this repeatedly - even if I was only tapping the brake. This is not the high-pitched whine that I normally hear when regenerative braking. That afternoon, the squeak was gone. The next morning, it did not come back. Never happened before, never again. It almost sounded like a squeaky piston or something, but wouldn't have been the actual brake piston because I was braking very lightly at speeds above 8mph. |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | The brake pedal actuates the master cylinder piston no matter what the speed of the car. If the power brakes are working okay, the master cylinder pushes against the stroke simulator, which is just a spring loaded piston. Either of these pistons or any part of the brake pedal linkage could be making this squeaking sound. Tom |
| Junior Member Join Date: Apr 2004 Location: Livermore, CA, USA
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | This sounds like the "barking brake" syndrome. See My Brakes are Barking at Me for past discussions. - Ed |
| LinkBack to this Thread: http://priuschat.com/forums/prius-technical-discussion/50199-altitude-braking.html | ||||
| Prius Technical Discussion: Blogs, Photos, Videos and more on Technorati | This thread | Refback | 07-09-2008 08:25 PM | |
| Altitude on the MFD. Why not? | darrylp | Prius Modifications | 5 | 02-12-2007 07:24 PM |
| Is there a GPS Altitude Readout? | bonanza34g | Prius Main Forum | 11 | 04-04-2006 11:00 PM |
| warning lights at altitude | jsb95003 | Care, Maintenance and Troubleshooting | 9 | 03-10-2006 12:09 PM |
| bladder attitude and altitude | mark_hamrick | Prius Main Forum | 0 | 07-16-2005 09:43 AM |
| Fix for Altitude | MarinJohn | Audio and Electronics | 5 | 05-05-2004 02:57 PM |
