Prius Technical Discussion This is a discussion on A discussion of gliding and a comparison of methods: pedal control vs. neutral within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Excellent report! With the data recorded, could you report the average speed for each method? It would be great to ...
comparison, glides:, neutral, pedal-controlled
LinkBack (2) Thread Tools
Old 07-26-2008, 06:41 PM   #21
bwilson4web
bwilson4web's Avatar
My Car: 2003 Prius
Package: #1
Nominated 2 Times in 2 Posts
Friends: 7
Default Re: A discussion of gliding and a comparison of methods: pedal control vs. neutral
Excellent report!
With the data recorded, could you report the average speed for each method? It would be great to compare the constant-speed MPG to either P&G method.
A minor variation, I used cruise control to handle P&G from 25-43 MPG.This allowed me to use cruise control "resume" to handle the pulse in a consistent fashion. Minor variation, it was my approach.
Thanks!
bwilson4web is online now
Old 07-26-2008, 08:22 PM   #22
JimboK
One owner, low mileage
JimboK's Avatar
Thanks, Bob.
I knew there was something I forgot! Interestingly, average speeds were virtually identical at 26.6 MPH. These include data only from when the vehicle was moving, excluding the red light stops and the force-charge segment.
JimboK is offline
Old 07-27-2008, 10:23 AM   #23
JimboK
JimboK's Avatar
One other inadvertent oversight in my reporting: ICE RPM. The target RPM for pulses was 1600. For the PC test, average pulse was 1615 RPM, median 1632. For the neutral test, the average and median both were 1632.
These were calculated on data points where RPM was >0 and pedal depression >20%, with one data point excluded from each set -- RPM was shown as 960 from where the ICE had not completely spun up at the beginning of a pulse.
JimboK is offline
LinkBack to this Thread: http://priuschat.com/forums/prius-technical-discussion/50385-discussion-gliding-comparison-methods-pedal-control-vs-neutral.html
PriusOnline.com • View topic - Coasting This thread Refback 11-12-2008 08:01 AM
HV Battry Charging While Gliding in N - CleanMPG Forums This thread Refback 07-31-2008 08:15 AM
A comparison of highway driving methods for the Toyota NHW20 Prius JimboK Knowledge Base Articles Discussion 17 01-08-2008 07:59 PM
Pulse and glide in neutral?? shastaprius Fuel Economy 7 05-22-2007 05:08 AM
My Method: "Pulse-Cruise / Neutral-Drive-Glide / Resume Mister Swigart Fuel Economy 39 03-23-2007 02:45 PM
Neutral Vs Glide darkecho Fuel Economy 26 09-15-2006 10:57 PM
Does the pedal move when you are in cruise control? LewLasher Prius Main Forum 5 03-22-2004 07:49 PM
