Prius Technical Discussion This is a discussion on p0010 dead throttle response no pedal within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; need help, got 06 prius, zero throttle, starts, runs for 1.5 this throws death triangle. pedal does no accelerating, replaced ...
dead, p0010, pedal, response, throttle
LinkBack (1) Thread Tools
Old 07-09-2008, 10:04 AM   1 links from elsewhere to this Post. Click to view. #1
xviperscom
Default p0010 dead throttle response no pedal
need help,
pedal does no accelerating, replaced pedal assy, replaced 12v batter, replaced throttle body and electronics. you can manually rev it up under the hood.also the on the mfd screen the battery starts to drop bars quickly.
any help would be greatly appreciated.
xviperscom is offline
Old 07-09-2008, 10:16 AM   #2
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 23
Default Re: p0010 dead throttle response no pedal
DTC P0010 "Camshaft Position 'A' Actuator Circuit (Bank 1)"
As you probably know, Prius has variable intake valve timing. The presence of this DTC means that either the oil control valve circuit has a problem, or the valve itself is bad, or the engine ECU is bad.
Patrick Wong is offline
Old 07-09-2008, 10:28 AM   #3
xviperscom
the car ran and drove, it came back to the garage and sat a little and won't start, what do know of the oil control valve, any easy circuit or parts to replace to eliminate to solve the problem.
i replaced the camshafte sensor too.
Old 07-09-2008, 10:58 AM   #4
Ct. Ken V
Hi, xviperscom,
It sounds to me like you're spend'g a lot of money replacing parts that may not even have needed replacing (weren't bad in the 1st place). I know many people have dealers that seemingly have no technical expertise in regards to the Prius & just seem to do the exact same thing, but I probably would have started at the dealer & let him pull the codes/run the diagnostics & look up what the potential causes & the recommended solutions would be. Going that route in the beginning might have actually saved you some money in your case. You probably can't return for a refund any of the parts you bought un-necessarily, but I hope you kept the old ones you removed because they are probably good still & may come in handy some day in the future.
Ken (in Bolton,Ct)
Ct. Ken V is offline
Old 07-09-2008, 11:11 AM   #5
Patrick Wong
DIY Enthusiast
Friends: 23
It sounds like you don't have access to the Toyota repair manual. I suggest you subscribe to techinfo.toyota.com so that you can download the relevant repair manual pages that explain how to troubleshoot the oil control valve. Looks like a fairly simple process.
Good luck.
Old 07-09-2008, 11:14 AM   #6
Patrick Wong
DIY Enthusiast
Friends: 23
Hi Ken,
It appears that xviper has a business selling used Prius parts, so the major investment here seems to be of his time.
Old 07-09-2008, 02:40 PM   #7
xviperscom
correct, i have a about 80 parts prius's here, so i have not spent a dollar on parts, not to mention car was high mileage and i don't regret replacing worn or damaged parts.
mastertech, snap on and tech manual are leading me no where and was just seeing if anybody has any useful info, thanks.
Old 07-15-2008, 05:26 PM   #8
spitinuri
Curious? Were you able to figure it out?
spitinuri is offline
LinkBack to this Thread: http://priuschat.com/forums/prius-technical-discussion/50605-p0010-dead-throttle-response-no-pedal.html
Prius Technical Discussion: Blogs, Photos, Videos and more on Technorati This thread Refback 07-09-2008 07:48 PM
More throttle ifo hobbit Prius Technical Discussion 9 06-03-2008 10:29 AM
A bad throttle motor froylance Care, Maintenance and Troubleshooting 4 04-23-2008 10:49 PM
Bad idle/low throttle. fine at higher throttle? robisaks Prius Technical Discussion 5 12-09-2007 11:54 AM
Dead Pedal - Notch mhawkin1 Prius Main Forum 3 07-06-2007 02:03 PM
2007 Yaris: To throttle, or not to throttle... nomadic1 Other Cars 5 03-09-2007 06:34 PM
