| Prius Technical Discussion This is a discussion on traction battery overheat within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; the last two days it's been 105 degrees + when i park i have 5 blue bars, 2to4 hrs. later ... |
| battery, overheat, traction |
| Junior Member Join Date: Jul 2008 Location: calaveras county ca.
My Car: 2004 Prius Package: #5 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | the last two days it's been 105 degrees + when i park i have 5 blue bars, 2to4 hrs. later iturn it on & i have two pink bars the engine must fast idle for 5- 10 min. as i drive the batt vent fan is running. your comments please. |
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | I wouldn't say the battery is overheated. The car babies the battery in several ways, including thermal management. Others have reported that when the battery reaches 104F, the car uses the ICE preferentially over the motors to power the AC (which I assume you're running) and limit current flow out of the battery, reducing additional ohmic heating. The result is more work for the ICE, which means higher RPM and less ICE-off time. I had an episode last summer of sluggish performance when OAT reached 104F. The consensus on cause was a hot battery (105F). In the midst of peak summer heat I take steps to keep the battery cool: park in the shade whenever possible, a windshield sunscreen, and cracking the windows. I also have window tinting. Once heated, the battery takes a while to cool, even with the battery fan and AC on. Better is to prevent it from getting so hot in the first place.
__________________ Jim Lifetime fuel mileage: ![]() After learning how to hypermile: ![]() Click here for car details. |
| Member Join Date: Jun 2008 Location: Albuquerque, NM
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
We generally don't hear it turn on for weeks at a time, but the single trip from which my wife has most often heard the battery fan is one that takes her downhill the better part of a thousand feet, then she parks for a couple of hour meeting. More than once, she has heard, and been puzzled by, the fan starting up fairly shortly after starting her return trip. As the meeting is an evening one, I suspect part of the setup conditions involve how recent and battery-strenuous here immediate previous trip was. The SG2 is in my Audi right now, when it goes back to the Prius I hope to get one of the published traction battery temperature XGauge settings working. I suspect I'll see something to surprise me. | |
| Senior Member Join Date: Oct 2007 Location: Gilbert, AZ
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | I don't know if increased humidity has anything to do with what you're experiencing but it's been a consistant 110-113 the last few weeks here in AZ and I have yet to hear my battery fan come on (although I haven't really tried to listen). I can tell you my car acts exactly like it does when it's cold. It'll run several minutes on battery, then when it gets down to 2 bars it will start up for a few minutes, then the ICE will turn off again. Acts like normal, just drains the battery a bit faster. Mike |
| Traction Battery Access | aeronaut | Prius Modifications | 7 | 07-15-2007 04:58 PM |
| When traction battery depletes.... | abq sfr | Prius Technical Discussion | 9 | 06-08-2007 05:09 PM |
| Traction battery charger? | chogan | Prius and Hybrid News | 1 | 06-05-2007 07:15 PM |
| Traction Battery Questiion | nwpa | Prius Main Forum | 22 | 01-31-2007 01:22 AM |
| traction battery replacement | PHLY50 | Prius Main Forum | 3 | 11-21-2006 10:00 PM |
