| Prius Technical Discussion This is a discussion on Fan blade orientation? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Hi Rob, Thanks for providing a very detailed writeup about your work. The Toyota repair manual is silent regarding the ... |
| blade, orientation? |
| | #21 |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 28 | Hi Rob, Thanks for providing a very detailed writeup about your work. The Toyota repair manual is silent regarding the correct fan rotation direction. The exploded parts diagram shows that one fan has seven blades while the other has five blades, but you have to look closely to note this. Prior to reading your posts, I had assumed that the two fans were the same and rotated in the same direction. |
| | #22 |
| Grumpy, Cranky Senior Member Join Date: Jun 2007 Location: Fullerton CA
My Car: 2007 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | Yikes! One fan goes to the left and the other to the right! Is there some sound technical reason for Toyota to have done this or is this political correctness run amuk?!?! Seriously, first place award for troubleshooting above and beyond the call of duty! ![]() |
| | #23 |
| Member Join Date: Jul 2008 Location: Redmond, WA
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | I think it may have something to do with the fact that Japanese fighter pilots held the P-38 Lightning in such high regard in WWII. Rob the docent at the Seattle Museum of Flight |
| | #24 | |
| Senior Member Join Date: Sep 2006 Location: King George, VA
My Car: Other Hybrid Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
Do you ever realize that on multi-engine prop planes, they have counter-rotating engines / props to decrease torque so the planes won't spiral out control? ![]() Well, Toyota, in their infinite wisdom, used the same engineering analysis and made counter-rotating fans? ![]() Word has it, they will follow suit in the 2010, and have the front wheels rotate opposite of the rear wheels! ![]() Last edited by JHSmith; 07-12-2008 at 12:04 AM. | |
| Rear Wiper blade | SalLema | Care, Maintenance and Troubleshooting | 4 | 06-05-2008 12:46 AM |
| wiper blade refills | Alphawolf | Prius Technical Discussion | 34 | 12-19-2007 04:41 AM |
| Navigaton Arrow Orientation - can I change? | powereli | Audio and Electronics | 5 | 11-20-2007 11:30 PM |
| Gear shifter orientation backwards? | aka007ii | Prius Main Forum | 15 | 10-29-2005 03:28 PM |
| Rear Wiper blade | Sal's Pride | IL - Chicago, Illinois | 0 | 12-31-1969 07:00 PM |
