| Prius Technical Discussion This is a discussion on 2008 Hid Lights - Adjustment/leave On? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; TO ALL of you that are technically well versed, i would like to ask you about the HID headlight system ... |
| 2008, adjustment/leave, lights |
| Senior Member Join Date: Feb 2008 Location: hollywood
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 12 | TO ALL of you that are technically well versed, i would like to ask you about the HID headlight system on my 2008 #6 prius. #1) is it safe to leave these lights on all the time as i drive? using it as a DRL option? safe meaning will it significantly shorten the life of the HID system? i mainly drive in the daytime, approximately 40-70 miles a day, depending on work loads. #2) when i do drive at night, i feel the HID system points too far DOWNWARD, it's not too bright for me. i would like to adjust the system a bit higher, but i do realize there is a self-leveler. Do i adjust the leveler or manually adjust the lights. forgive me in advance if this is a multiple post, i tried to research HID, but nothing significant showed up. my car being black, i'm noticing people NOT being able to see me as much as the lighter/brighter colors. i have to also admit that i'm a bit afraid to get hit or cutoff.............................our cars are very rare to purchase now! ![]() ![]() |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | 1) It is safe to leave them on all of the time, but capsule life will be shortened. The capsules are fairly expensive to replace if you do it yourself. If the dealer does it, they are outrageous. 2) The downward aim is mostly a function of the brightness and sharp cutoff of HID lights. Most of us are used to normal headlamps, which spill a lot more light down the road and into the eyes of oncoming traffic. Good HIDs have a very sharp divide between the light and the dark. Yours are probably adjusted the way they should be. If you really need to adjust them, there is a screw adjuster on each lamp assembly. Tom
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 12 | QBEE - thanks tom, are the adjustment screws easy to find? i haven't taken a look, but if i manually adjust them, will the self leveler compensate for this? for example, i aim it a bit higher, the leveler automatically compensates. will this be the case? |
My Car: 2007 Prius Package: #5 Nominated 6 Times in 1 Post TOTM Awards: 0 Friends: 47 | The auto-leveler for the HID headlamps compensates for the attitude of the car. If you load weight in the back, so it sinks lower under the weight, the front of the car points upward and the HID lights could blind oncoming drivers. The screws on the back of the lights set where the lights point and the auto-leveler keeps them pointed at the same spot with a load. Don't go blinding other drivers. |
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 12 | BILL - i have no intentions of blinding other drivers. as i said in my OP, i have problems seeing at night with my HID system. |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 23 | Hi Gene, The more that you use the HID headlights, the more quickly the expensive bulbs will fail. However if you feel that having them on during the daytime is a helpful safety measure, then peace. Regarding headlight aim, I assume your car is under warranty, so why not have your dealer check the aim and correct it if necessary. Maybe the auto-leveling mechanism is not working, which causes the aim to be too low. |
| uphill battling Join Date: Mar 2005 Location: central NC/ western WI
My Car: 2005 Prius Package: #5 Nominated 5 Times in 3 Posts TOTM Awards: 0 Friends: 19 | as others have said, you will burn out the bulbs more quickly by having them on all the time. stick a couple bucks away every month into a bulb replacement fund and you'll be fine. as an unexpected expense, it's a bit of a shock. since HIDs are so bright, a professional adjustment is safest. DH does not even give out instructions for adjusting these, because the cutoff line for blinding other drivers is so fine. |
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 12 | NOW that makes sense. Thanks for the constructive help. i'll bring it to the dealer - make sure the lights are pointed in the right altitude. i doubt they are correct because my daughters #2, standard bulbs, light up the street - making it easier for me to see. This can't be right with the HID's. |
| Senior Member Join Date: Mar 2008 Location: San Diego, CA
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Quote:
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Quote:
Take your car out at night onto an empty road, and switch between high and low beam. If the high beams give you good illumination down the road, then the lights are adjusted properly. Most likely it's just a matter of you not being used to the sharp contrast of bright and black caused by the sharp cutout of the HID low beams. That's the way they are supposed to work. If, on the other hand, your high beams are pointing down, then take your car to the dealer to get the lights adjusted. Tom | |
| i want to install fog lights on 2008 prius | jdjord2 | Newbie Forum | 2 | 04-03-2008 07:34 PM |
| anyone changed the fog lights to white lights if so does it math the color of the LED headlight? | sea-horsea | Prius Main Forum | 7 | 02-05-2008 03:15 PM |
| Does Fog light MOD leave lights on after driver door opens? | Jakabite | Prius Modifications | 2 | 10-13-2007 12:27 PM |
| Auto Lights and Seat Hight Adjustment? | Black2006 | Prius Main Forum | 12 | 04-11-2006 02:04 PM |
| Leave your lights on? | coondognd | Prius Main Forum | 7 | 03-15-2004 04:29 AM |
