| Prius Technical Discussion This is a discussion on ND-11 Oil for the A/C system within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I have a 08 Prius that was in a previous front end collision that required the radiator and condensor to ... |
| nd-11, system |
| Junior Member Join Date: Jul 2008 Location: California
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I have a 08 Prius that was in a previous front end collision that required the radiator and condensor to be replaced. Everything else has been restored but the recharge of the A/C system. It's no longer under warranty because of the collision.... My questions is, How much of the ND-11 Oil do I use?, Where do I insert it? and how much freon do I use? I already purchased the Oil from the toyota dealer and it comes in a regular bottle with a twist off cap with hardly any oil inside. It would have to be poured in something or directly in the high or low pipes of the A/C system. I tried asking the dealer about it and they pretended they didn't know, they advised me to find it on the internet. Quite disappointed of all the business that was done with toyota and all they can say is that! I would appreciate any feed back or technical input given. Thanks! |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 28 | Suggest you consult techinfo.toyota.com which is a subscription website where you can download repair manual pages. Good luck. |
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote: Thanks for the feed back and the illustrations provided, Dogfriend, much appreciated! Last edited by PHLOS; 07-16-2008 at 11:43 AM. | |
Thanks for the feed back! Last edited by PHLOS; 07-16-2008 at 12:09 PM. | |
| Member Join Date: Mar 2008 Location: Idaho
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I put 1.4 oz oil in the line from the A/C gauges to the low side line on the prii as I only replaced the condenser...When I added the 134 It blew it right in...Be sure to evacuate the system first.... |
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I ended up calling another dealership and had it recharged by them for $125 and also returned the oil I bought to the other dealership that gave me the hassle. Apparently each dealership is independently owned; thank goodness for that! The A/C is working perfectly.... Thanks for all your responses. |
| Should we buy the nav system? | MtnBiker | Audio and Electronics | 24 | 05-17-2008 12:46 PM |
| '08 Nav System | kathyb | Audio and Electronics | 2 | 02-05-2008 12:15 PM |
| dvd for gps system | felix1 | Prius Main Forum | 1 | 01-24-2008 05:30 PM |
| Where is the DVD for the Nav System | karat | Care, Maintenance and Troubleshooting | 9 | 10-05-2006 09:16 AM |
| NAV system for $130 IF... | DaveinOlyWA | Audio and Electronics | 1 | 09-20-2004 09:50 PM |
