Prius Technical Discussion This is a discussion on explain this photo within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Unfortunately, I've seen it before. I just comes from starting the car cold, driving it around like a wild man ...
explain, photo
Old 07-18-2008, 06:42 PM   #11
a priori
a priori's Avatar
Default Re: explain this photo
Unfortunately, I've seen it before. I just comes from starting the car cold, driving it around like a wild man and then parking it without turning it off.
Really, you don't need to have driven it wildly, you only need to have turned it on, moved it a little bit and then parked it in ready for more than 5 minutes. They very likely pulled it from the lot, drove it up to the garage for a photo and left it in idle whilst taking pictures.
(I do kind of like the other, more imaginative options a bit better than mine.)
Some knowledge may be readily grasped as it is apparent to even the most casual viewer, but most of us learn this only by experience after having ignored what was right before our eyes.
a priori is offline
Old 07-18-2008, 06:47 PM   #12
JimboK
One owner, low mileage
JimboK's Avatar
I agree that the visible bar is likely a short drive, maybe no more than around the parking lot, that burns a little gas. Then it was allowed to sit still in READY long enough for the "invisible" bar to register.
JimboK is offline
Old 07-18-2008, 07:46 PM   #13
TonyPSchaefer
Ruler of Omicron Persei 8
TonyPSchaefer's Avatar
Nominated 4 Times in 2 Posts
Send a message via AIM to TonyPSchaefer Send a message via MSN to TonyPSchaefer Send a message via Yahoo to TonyPSchaefer
Friends: 16
I think you give them too much credit. If that car were driven around the parking lot, the bar would be higher simply due to the fact that there would be more "miles" into which to divide the "gallons." I actually use this technique starting my commute intentionally driving out of my way to make sure I do not sit as Priapus warms up.
I propose that six minutes prior to taking the picture, the car was moved a little. Since it was in warm-up mode, it sat there and idled. Of course, Free Bird was on the radio so he sat there and listened to it. Then the guy left it on, went inside, got the camera, came back and took the picture.
But I do agree that 19MPG is easily achievable in parking lots where the car is jockied around and never gets the opportunity to achieve full warm up and certainly doesn't have the opportunity drive under ideal circumstances to earn some decent mileage.
Proud father of Priapus: the '04 Tideland BC9 with an OEM EV button and sense of self-righteousness >>Current Mileage<<
Spreading information and passing gas in the Greater Chicagoland area
Click this hyperlink PLEASE. It's not a trick; it's a competition.
http://www.facebook.com/login.php?ap...code=pass,2357
TonyPSchaefer is offline
Old 07-18-2008, 08:19 PM   #14
JimboK
JimboK's Avatar
OK then, a real tiny parking lot.
JimboK is offline
Old 07-18-2008, 09:06 PM   #15
TonyPSchaefer
Friends: 16
[Monty Python]
Oh well, a real tiny parking lot maybe, but not a very large parking lot. That's what I'm saying.
[/Monty Python]
Old 07-21-2008, 06:03 AM   #16
bbald123
Thermodynamics Law Enforcement
This is normal. This is what my MFS looks like when I'm stuck in traffic with a cold ICE.
bbald123 is offline
Old 07-21-2008, 08:57 AM   #17
ursle1
Realist
this is what mine looked like when I picked the car up new from the dealer, lot's of idleing while checking under the hood for rats, or getting paid to check for rats but leaving them there, or the blind leading the blind, it idles for hours because the dealer is clueless, like the dudes at carmax
ursle1 is offline
Old 07-25-2008, 03:44 PM   #18
Viscor
Nominated 1 Time in 1 Post
1st bar: Drive up hill with AC on full? Drive your car like a 16 year old with his 1st car?
2nd bar: Piece of cake. Leave the AC on full while parked. Your gas engine will start running and you'll get a bar with zero mpg over 5 minutes.
Viscor is offline
Can you explain what P&G is??? freshmtt Prius Main Forum 21 05-04-2008 11:30 PM
Explain this for me pixeltaker Fuel Economy 12 06-13-2007 11:44 AM
Can someone explain why you get better MPG in... burritos Fuel Economy 8 02-27-2006 02:04 PM
Can someone explain something to me? yarzy Prius Main Forum 6 01-12-2006 07:31 PM
