| Prius Technical Discussion This is a discussion on Water keeps collecting on rear, passinger floor within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; The simplest cause is usually the likeliest. At some point did you have a formerly full water bottle under the ... |
| collecting, floor, passinger, rear, water |
| | #21 |
| Senior Member Join Date: Mar 2007 Location: Albuquerque, NM
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | The simplest cause is usually the likeliest. At some point did you have a formerly full water bottle under the seat or in a gym bag nearby? |
| | #22 |
| nacreous lacquer Join Date: Mar 2004 Location: United States
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I keep my A/C on recirculate exclusively. Living here, if I used outside air the cabin would always be filled with vehicle exhaust. This may possibly help keep the evaporator clean; there should be little more than exhalation condensates in it. |
| | #23 |
| Junior Member Join Date: Jul 2008 Location: Rockford, Il
My Car: 2003 Prius Package: Pioneer #1 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Another update... I went to a repair shop and they told me the rubber A/C drain tube was pushed up so water was being directed inside the car. I also found out that there was indeed plenty of water in the front seat floor, but it was underneath a pan so I didn't see it. Now, I have the the carpet loose so I can try to dry things out. The guy at the shop said either something bounced up and knocked it inside the car or somebody did it as a prank. It is not easy drying things out since we are having high humidity. It seems I will have to fight the mold & mildew monsters. |
| | #24 |
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | That sucks. At least it has been fixed. Run the A/C constantly to help dry things out. |
| Hexomats: Front and Rear floor mats. | moolman | Prius Main Forum | 0 | 03-17-2007 09:22 PM |
| Rear Open Floor Space | A. B. Hair | Prius Technical Discussion | 12 | 08-03-2006 05:25 PM |
| How to reattach rear floor board (over HV batts)? | afternoonnap | Care, Maintenance and Troubleshooting | 5 | 10-28-2005 03:48 PM |
| Brand new '05 Gray FLoor Mats, front and rear | LuckyP | Private Sales | 1 | 07-13-2005 05:39 PM |
| one piece rear floor mat | tombaskin | Prius Modifications | 2 | 11-24-2004 08:23 PM |
