Prius Technical Discussion This is a discussion on hybrid system malfunction. engine not kick in within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; hi bwilson4web: I agree with what you said. but why is unrelated codes appeared at the same time? for example, ...
engine, hybrid, kick, malfunction., system
Old 07-22-2008, 05:42 PM   #11
hc167
Default Re: hybrid system malfunction. engine not kick in
hi bwilson4web:
I agree with what you said. but why is unrelated codes appeared at the same time? for example, why is there a keyless entry code there? anyway, I understand your point. but I believe if there is a problem, then the code will come up again. I will buy a scanner and do it myself. I generally do not 100% believe those dealer. especially when they hire those young guys to work on my car. And I do think that toyota is a good car with good hardware. I just don't trust on their software.
anyway, maybe I should mention one more thing, that check engine light came on when I reset the service maintenance light without changing oil two days ago. I did that because my last oil change I used mobile 1 and the condition of the oil is still good. Please don't tell me that this will bring up the check engine light.
hc167 is offline
Old 07-22-2008, 05:57 PM   #12
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 28
Without knowing what the DTC are, how can you assert they are unrelated? For example, a problem with the DC to DC converter could cause the voltage on the 12V bus to sag. This would cause DTC to be logged by various ECUs which might not appear to be directly related to each other.
If the check engine light is coming on, then the engine ECU is logging DTC. However, without a list of the DTC, it is hard to say whether your problem is as simple as a loose gas cap, or an ignition misfire, or a bad catalytic converter, or failed variable intake valve timing, or a bad engine coolant heat recovery system, or ??
Hence, it would be wise to ask your dealer tech to carefully record all retrieved DTC and enter them upon your service invoice, so that you have a record for future reference.
You can buy an OBD-II code reader. I suggest that you ensure that it is compatible with the Toyota communications protocol. Even if compatible, it may or may not pick up the DTC logged by the various Prius ECUs.
2006 Highlander Hybrid 4WD-i
2000 Ford Mustang GT conv.
Patrick Wong is offline
Old 07-22-2008, 06:16 PM   #13
richard schumacher
nacreous lacquer
Or even as simple as the 12V battery being low. Is this the original 12V battery? Have you ever drained the 12V battery by leaving a door or the hatch open, or the lights on?
richard schumacher is offline
Old 07-22-2008, 06:59 PM   #14
hc167
I have never drained the battery. but the dealership that I purchased did. This is the car that I purchased used last year. and when I tested drive the car, they actually needed to jump start the car. anyway, I will need a scanner with me. I do not really trust the dealer. Not that because they do not have the knowledge. but they never want to do a good job on my car (I should say anyone's car). and for a small problem. they keep telling you that this entire thing need to be replaced. I will ask my friend about my car check engine light issue. he can access alldata. So maybe I can find some information there. yes, you are all correct. they maybe related issue.
hc167 is offline
Old 07-22-2008, 07:00 PM   #15
hc167
yes, it is the original battery
hc167 is offline
Old 07-23-2008, 07:46 PM   #16
hc167
my check engine light is on again today and I sent it to dealer. They did a quick scan and only found one code this time. I did not ask them the code but they said it is the generator sensors. so they will need me to drop off the car for about one day.
hc167 is offline
Old 07-23-2008, 08:59 PM   #17
statultra
uber-Senior Member
statultra's Avatar
Send a message via AIM to statultra
if you buy a scanner make sure it supports CAN protocol.
if anything happens again it should be covered under warranty instead of being erased by the dealer, if you send it back ask for a printout of the diagnostic check.
statultra is offline
diagnosis for P3191 (engine does not start) and P3101 (engine system malfunction) wayne w International Owners 7 10-30-2008 01:18 AM
Engine light = bad hybrid system coolant valve: Warranty? Help! mstucky Prius Main Forum 3 10-23-2007 11:46 AM
Hybrid system appears to protect cold engine theorist Prius Technical Discussion 15 07-15-2006 04:59 PM
Hybrid System Malfunction Indicator... malfunctioning? redstapler Care, Maintenance and Troubleshooting 10 01-03-2005 04:13 PM
Should I feel the Engine Kick on and off? TimeFor Prius Main Forum 9 10-21-2004 01:09 PM
