| Prius Technical Discussion This is a discussion on MFD shows incorrect engine status within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Originally Posted by Rest Here is something that may be an error. When I drive in that sweet spot, no ... |
| engine, incorrect, shows, status |
| | #11 | |
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Quote:
However, you are correct that there is current flow out of the battery during a sub-41 MPH no-arrows condition -- a "glide" as most of us regulars in these parts call it. There appears to be a more-or-less linear relationship between current flow (up to 8 amps) and vehicle speed when using go-pedal feathering. On the other hand, using neutral to glide uses considerably less current and maintains SOC longer, though at the price of slightly increased drag. See this for more.
__________________ Jim Lifetime fuel mileage: ![]() After learning how to hypermile: ![]() Click here for car details. | |
| | #12 |
| Member Join Date: Sep 2007 Location: US
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | yes, when the car is not moving and you step on the brake. there is an arrow from the battery to the motor. that is normal. because it is powering the motor. why is that, because you did not step on the brake hard enough. do two tests, when you see this happen next time, either hit the "park" button or hit the brake harder. that will deactivate the power from battery to the motor. it is just like regular car when you stop at "D", the engine try to move the car but your brake try to stop the car. prius try to simulate this by activate and deactivate the motor at the position of the brake that you step on. |
| | #13 |
| nacreous lacquer Join Date: Mar 2004 Location: United States
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The cartoon only shows energy flows within the drive system. Energy flow out of the battery to the A/C, lights, accessories, etc. is not shown. |
| Incorrect or over simplified transmission description. | okiebutnotfrommuskogee | Prius Main Forum | 15 | 10-27-2007 07:27 PM |
| Three Politically Incorrect Editorials | TimBikes | Fred's House of Pancakes | 20 | 04-18-2007 12:35 AM |
| Warning: Incorrect part listed | xxxlmpg | Prius Main Forum | 3 | 06-09-2006 11:56 PM |
| GM engine plant achieves landfill-free status | andrewgs | Environmental Discussion | 4 | 05-18-2006 04:11 PM |
| Possible incorrect color displayed at US site | Three60guy | Prius Main Forum | 10 | 12-11-2005 08:54 PM |
