| Prius Technical Discussion This is a discussion on Possible alignment problem and brake pulling within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Originally Posted by olimpicars My dealer reported that the cause of the occasional pull to the left was a combination ... |
| alignment, brake, problem, pulling |
| | #11 | |
| Member Join Date: Apr 2007
My Car: 2007 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
When I relocated to the Seattle area, I had another Toyota dealer check the alignment after explaining my alignment history. They said it was right on the target specs. I brought it back a few weeks later insisting it was not right. I had really noticed the poor handling after driving their loaner Corolla --- the Corolla felt secure and tracked true and cornered beautifully. They checked it again - same story and they swapped the front tires & wheels with the rears. Bottom line, no change. All of the checking & swapping was done under warranty. So now my plan is to go to a local alignment shop that has a great reputation and explain the situation to them and hope they can fix my problem. I'm open to any thoughts. And yes, I always check the pressures and they're always the same 40/38.
__________________ Mark | |
| | #12 |
| Junior Member Join Date: Jul 2008 Location: Middleburg, Virginia, USA
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Mark: I'm no expert, but your car might handle differently, and better, if you set the pressures to 36 front- 33 rear per the owner's manual. My dealer likes 35 all the way around. (Higher front tire pressures have a way of negating the natural tendency of a front wheel drive car to understeer). And, it goes without saying, set them cold, first thing in the morning. I find that my car is very sensitive to changes in the camber of the road, and the higher pressures that you're running just might be decreasing the contact patch enough to have an adverse effect. Just a thought. |
| Pulls Left: Dealer Says Tire is to Blame; not an Alignment Problem | a priori | Care, Maintenance and Troubleshooting | 18 | 07-27-2008 12:30 PM |
| Brake Actuator Problem | redbluff | Prius Technical Discussion | 4 | 07-23-2008 03:14 PM |
| New Brake Problem | saechaka | Prius Main Forum | 20 | 05-02-2006 01:16 AM |
| Is anyone having problem with brake??? | Speedracer | Prius Main Forum | 33 | 01-10-2005 02:01 PM |
| Disk brake problem | williaeh22 | Care, Maintenance and Troubleshooting | 1 | 05-04-2004 03:52 PM |
