| Prius Technical Discussion This is a discussion on What constitutes a charge and recharge? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Well, I said in the newbie forum that I would not author any more posts other than to thank the ... |
| charge, constitutes, recharge? |
| Junior Member Join Date: Jul 2008 Location: Portland, OR
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Well, I said in the newbie forum that I would not author any more posts other than to thank the senior members for all their information and advice. But now I have a question I cannot seem to find anywhere else and I wonder... Does a charge / recharge cycle of the traction battery happen each time the car is driven regardless of how much or little the stored power in the battery increases and decreases? or Is a charge / recharge cycle not complete until the level goes from green to pink and back over the course of several drives? Is it known anywhere roughly how many of these charge / recharge cycles the battery system will do? Or are there too many variables to answer? Thanks for the invite to the Portland group, Bill. |
My Car: 2007 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The Prius battery -never- goes through a "charge" cycle. It is constantly being discharged a bit and recharged a bit. This is the whole idea of the design, never discharge below about 40% and never charge above about 80%. I suppose if you managed to get it down to 40% you could say it was then being charged, but that happens all the time and only partially. Ditto if you get all green bars. The system then tries to "use up" some of that charge, but it will still dump charge into the battery on braking if you get it down even slightly. So there is no real "charge/discharge" cycle. The battery is constantly being charged and discharged as needed, never letting the SOC (state of charge) get below about 40% and above about 80%.
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Thank you, David. I understand that concept and have seen those statistics around. But certainly there is a finite limit to the number of times this happens... Have any Prius Nickel batteries "worn-out" yet do we know? |
| Senior Member Join Date: Oct 2005 Location: Long Island
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | "Recently" totalled in an accident, there was a Gen 1 Prius (Owner: Jesse) with over 300K miles on it w/ the original battery. A few years back...there was a Prius taxi in Canada w/ over 100K miles on the original battery. Except for, maybe, the rare manufacturing defect, I have never heard of a Prius traction battery wearing out (except maybe for some bad mods that damaged things). |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Obviously there is a finite limit to charge cycles. The reason the question is hard to answer is that it depends on the depth of the discharge/charge cycle. Some types of batteries that can only go through a couple of hundred full cycles can go for thousands of shallow cycles. The answer also depends on how you define dead. Is a battery at 50% capacity still alive, or is it dead? The Prius uses a very shallow cycle, and it will still function well at 50% battery capacity. Because of this the traction battery will last for over 200,000 miles, on the average going through several small cycles for each of those miles. Tom
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 28 | Quote:
2001 Prius at 61K miles, DTC P3006 Battery SOC Uneven 2006 HiHy 4WD-i at 26K miles: DTC P0A80 Replace Hybrid Battery Pack DTC C1259 HV System Regenerative Malfunction DTC C1310 Malfunction in HV System I have 56K miles on the 2004 Prius and the SOC gauge seems to show 7 and 8 green bars more than before - maybe this is early warning of an impending failure? If you look at my Classic Prius Repairs poll, you will see five out of 32 respondents who have reported the need to replace the traction battery. Classic Prius Repairs
| Member Join Date: Sep 2007 Location: US
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | by the way, do anyone know if the MFC display actually show the battery being charged to full level? I seem that sometime in the last four months. it doesn't happen all time. and before last four months, I have never seem that happen. |
| Member Join Date: Jun 2008 Location: Albuquerque, NM
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
Depending on how I hit stoplights, if any, temperature, etc. that generally gets me to seven or eight bars by the end. But I believe if I launched into regular stop and go city traffic on the level, or a level Interstate, I'd probably never see eight bars. By the way, I fear this may mean I'm using up my battery life faster than do flatlanders. | |
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | Quote:
Rob | |
| Smart Key Recharge | ethanhunt | Prius Technical Discussion | 10 | 01-09-2008 10:32 AM |
| Recharge Air on my 01 Prius | Joekingiam | Prius Technical Discussion | 1 | 09-06-2007 11:00 PM |
| air conditioning recharge | rshultz | Prius Technical Discussion | 13 | 05-24-2007 08:15 PM |
| How often do you recharge the key? | dachshund | Prius Main Forum | 32 | 10-22-2006 08:41 AM |
| Recharge you hybrid battery? | fisherman | Prius Modifications | 8 | 12-07-2004 08:00 AM |
