Prius Technical Discussion This is a discussion on Rat-tat-tat noise when opening drivers door within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Originally Posted by echase I don't understand why the brake pump would be triggered by opening the drivers door. I ...
door, drivers, noise, opening, rat-tat-tat
Old 08-04-2008, 10:22 AM   #11
hill
High Fiber Member
hill's Avatar
Default Re: Rat-tat-tat noise when opening drivers door
Originally Posted by echase View Post
I don't understand why the brake pump would be triggered by opening the drivers door. I assume this behavior is reliably reproduced by opening the drivers door after the car has sat idle for some time?
It's not from opening the door(s). That's just a co-inkydink. It'll happen before or after opening the door. Sit there long enough, & it'll go off before the door opens, sometimes. Jump out quick, & it'll go off after, sometimes. But sometimes, not at all. It just depends on the need for recharge.
hill is offline
Old 08-06-2008, 06:28 PM   #12
Rhymer
Spent some time with my Toyota Service Manager, and he listened and convinced me, as did Tom, that it was the brake accumulation pump, and is a normal function on the Prius. Thanks for all the replys.
Rhymer
Rhymer is offline
REd sign on dash when opening door Flying White Dutchman Prius Main Forum 9 03-30-2008 12:37 AM
Creaking, Door opening noise when the AC on freddyfoxx Prius Technical Discussion 4 10-17-2007 11:27 PM
Buzzer went off when opening driver's door Springtime Prius Main Forum 11 02-02-2006 12:23 PM
Trunk door popping noise faigor01 Prius Main Forum 4 06-14-2005 11:09 AM
Long beeeeeeep on opening the door. jeepien Prius Main Forum 14 01-20-2005 12:03 AM
