| Prius Technical Discussion This is a discussion on Automatic B-mode at 84% SOC within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Originally Posted by ken1784 When I saw 82.5% SOC, the battery temperature was 50C and I could not activate the ... |
| automatic, b-mode |
| | #22 |
My Car: 2006 Prius Package: #7 Nominated 7 Times in 2 Posts TOTM Awards: 0 Friends: 18 | I have this "B-mode" recorded from my can-view. As soon as I get back from my Hymotion battery install I will extract the data and post the results. I got this B-mode a few times coming down the mountains today. I'm sure I will get it a few more times on the way back home. This B-mode started when SOC reached about %80-%81 according to the can-view. I dont think I got the SOC any higher than %82. |
| | #23 |
| mountain rider Join Date: Jul 2008 Location: Buffalo, Wyoming
My Car: 2007 Prius Package: #2 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | As to the heat in the battery, the battery is a heater both charging and discharging. Any "excessive" heating would be caused by inadequate cooling control or by battery cooling design flaws. It would appear, from the low numbers of destroyed batteries reported, that battery temperatures reported so far are "normal" for the system. Even EV mode recognizes those numbers as possible and has strategies in program. So far I have no idea what monitoring takes place of the cells in the battery but gross temperature of the "battery" is probably only one thing being noted by the system and until we have a breakdown of the code there is no way of knowing for sure what the machine is actually doing about instantaneous inputs. Is it the battery temperature being measured or the temperature of the air flow around the battery? From what does the temperature signal come? Does the system monitor individual cell condition? Cell bank condition? Insufficient data and insufficient error report to be concerned. |
| | #24 | |
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Quote:
It also monitors overall pack voltage, which it presumably uses at least in part to figure SOC. I don't know whether it monitors voltages of individual modules or cells, though my (mostly uneducated) hunch is that it probably does. | |
| | #26 | |
My Car: 2004 Prius Package: G Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Quote:
Ken@Japan | |
| | #27 | |
![]() As I researched this today, I reread this, verifying (on page 7) your statement. I wasn't second-guessing you, BTW. I regard you as among the most credible and knowledgeable of experts on PriusChat. I just wanted to reconcile discrepancies between this, statements of others, and my own understanding. Here’s what led me to make my statement. The temperature that CAN-View reports is described on the CV web site as "the temperature of the hottest battery cell." I inferred from that that all cells are monitored, otherwise the hottest couldn’t be determined. The CV serial data output includes values for “minimum” and “maximum” battery temperatures. My mistaken understanding was that these too were cell temperatures. That understanding came from a flawed recollection of this site that describes the CAN decoder application I use with CV. The site actually describes the temperatures as module temperatures, but that too obviously is wrong.
__________________ Jim Lifetime fuel mileage: ![]() After learning how to hypermile: ![]() Click here for car details. Last edited by JimboK; 08-14-2008 at 08:59 AM. | |
| "Doggie in the car Mode"-- READY Mode, AC On & Remotely Lock doors? | bob749prius | Prius Technical Discussion | 15 | 08-14-2008 12:18 PM |
| What's this I saw on ebay?: Prius AUTOMATIC EV MODE-ALL MODELS/YEARS NW10-NW11-NW20 | andrewsilver | Prius Main Forum | 5 | 06-09-2008 11:23 PM |
| Automatic EV-Traction mode during warmup? | echase | Prius Modifications | 2 | 06-06-2007 10:20 PM |
| Yes dad, it's an automatic | bredekamp | Prius Main Forum | 7 | 05-08-2007 05:36 PM |
| Automatic A/C | glscheil1 | Prius Main Forum | 2 | 04-19-2004 09:39 AM |
