| Prius Technical Discussion This is a discussion on Automatic B-mode at 84% SOC within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I thought I read somewhere that the Prius battery does not benefit from being at 100% SOC and tries to ... |
| automatic, b-mode |
| | #31 |
| Kinda Jovial Member Join Date: Jan 2008 Location: Stafford, Virginia
My Car: 2008 Prius Package: #2 Nominated 6 Times in 2 Posts TOTM Awards: 0 Friends: 2 | I thought I read somewhere that the Prius battery does not benefit from being at 100% SOC and tries to put it in the SOC sweet spot for long battery life. |
| | #32 |
My Car: 2006 Prius Package: #7 Nominated 7 Times in 2 Posts TOTM Awards: 0 Friends: 18 | Here is the section of data relating to the b-mode. Its in xcel format if anyone wants to graph things out. B-mode is entered when SOC is greater than %80. http://jaygroh.dreamhost.com/priusch...data/bmode.xls |
| | #33 |
My Car: 2005 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | Guys, I've got a mountain commute and I've noticed that I rarely get full bars. I regularly get into the first green bar, but the last one rarely turns green. Don't have a CV so I don't know the precise SOC. I switch between B and D depending on the grade. There are a few pretty steep parts (8-10% grades) where I use B and for the rest it's pretty much D. OAT usually ranges from around 65 deg F to 90 deg F on this commute. Today I think it was in the 60's all the way down the canyon. I have EV mode, but it seems to have malfunctioned because it hasn't worked in months (I've got the coastal tech mod). Any ideas?
__________________ Cheers, Tripp 2005 Silver Pkg 3, OEM Block Heater, Coastal Tech EV mod, BT Tech Chassis Stiffener, hell damned infernal reverse beep disabled Boulder Real Estate ![]() Howay the Toon!"Sometimes when you aim for the stars, you hit the moon." -- Ian Holloway |
| | #34 |
| Italian Prius Expert Join Date: Jan 2006 Location: Turin, Italy
My Car: 2005 Prius Package: T Spirit Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Yesterday I came back home passing the Stelvio Pass: I managed to drain TOTALLY the battery: It will not go under 29% and only then the system would refuse to accelerate the car from a hairpin turn. I got to the top that SOC was reading 32%, and temperature was 115 F. Just for curiosity, mileage was reading 30.1 MPG at the top. Coming down, when the battery reached 70% the temperature reached 130 F and the system was not accepting an input charge anymore. |
| "Doggie in the car Mode"-- READY Mode, AC On & Remotely Lock doors? | bob749prius | Prius Technical Discussion | 15 | 08-14-2008 12:18 PM |
| What's this I saw on ebay?: Prius AUTOMATIC EV MODE-ALL MODELS/YEARS NW10-NW11-NW20 | andrewsilver | Prius Main Forum | 5 | 06-09-2008 11:23 PM |
| Automatic EV-Traction mode during warmup? | echase | Prius Modifications | 2 | 06-06-2007 10:20 PM |
| Yes dad, it's an automatic | bredekamp | Prius Main Forum | 7 | 05-08-2007 05:36 PM |
| Automatic A/C | glscheil1 | Prius Main Forum | 2 | 04-19-2004 09:39 AM |
