Prius Technical Discussion This is a discussion on Air filter system and MPG within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; If this air resonator boxes is anything like the others I've been around it does little more than reduce noise ...
air filters, mpg
Old 08-08-2008, 05:01 PM   #11
Shawn Clark
Shawn Clark's Avatar
Default Re: Air filter system and MPG
If this air resonator boxes is anything like the others I've been around it does little more than reduce noise from the intake. When I put air horn set ups in my Nissan and Honda I disconnected the resonators. Gas mileage was unaffected, and power improved. (Of course, making use of the extra power hurt gas mileage, but not during cruise.) Doing this gave the Nissan a more throaty sound but not in an objectionable way--probably because the 2.4L had the same bore & stroke as a V-8. It had a mellow burble after the change. The Honda without air resonator connected had more of a staccato sound at higher rpm when the VTEC kicked in, otherwise it wasn't really noticeable.
FWIW, I suspect disconnecting the air resonator in the Prius with Atkinson compression would be more objectionable sounding than the Accord was.
Shawn Clark is offline
Old 08-08-2008, 06:29 PM   #12
echase
Originally Posted by azsaxguy View Post
BTW - I just guessed about the "package" I have no idea what package I have. How do I find out?
Azsaxguy
Um, just whip it out and measure it.
The package determines what kind of goodies you get to play with.
The best goodies are for guys with 9# packages.
/END JUVINILE DIVERSION
echase is offline
Old 08-08-2008, 08:12 PM   #13
JimN
Certified Prius Advisor
JimN's Avatar
Yes, humidity & air temp are factors. Too cold & the ICE runs just to keep itself & the catalytic converter warm. Too hot or cold & the battery is not as efficient. Humid air is less dense so performance takes a hit. Altitude is also a factor.
My car seems to run best when the temps are in the high 60's to low 70's.
JimN is offline
Old 08-11-2008, 11:39 AM   #14
Old Bald Guy
BTW - does outside temperature and or humidity make any difference?
Saxguy
Yes, outside temperature can make a BIG difference in your mileage ... especially if your car sets out in the sun and cooks for awhile. It's not so much that the heat itself cuts mileage ... but rather it's what the battery pack does when it gets really hot.
I live near Dallas, TX and it can get pretty hot here. My normal MPG on any tank averages around 52 mpg. On a recent fillup, the car had been outside in the sun for hours on a 105 day ... so the car ... and the battery pack got really hot.
For the rest of that day, my mileage was about 44 mpg. I park in a garage and the next couple of days the temp outside was in the 80's. Two days of that much lower temperature and my mileage reading was back to over 52 mpg.
The battery pack is air cooled with the air conditioned air from inside the car ... but when it gets really hot from cooking in the sun, it just doesn't cool down very fast. And when it is really hot, it has a lot less power.
Old Bald Guy
2008 Prius package 2
Old Bald Guy is offline
Engine air filter - upper filter? petteri Care, Maintenance and Troubleshooting 8 Yesterday 09:59 AM
For Sale Cabin Filter, Oil Filter, Engine Filter moolman Private Sales 6 06-25-2008 08:23 PM
K&N Air filter... itg Prius Modifications 19 05-26-2008 03:24 PM
Oil Filter Walker1 Care, Maintenance and Troubleshooting 25 02-01-2006 09:30 PM
air filter Angel Flight Pilot Care, Maintenance and Troubleshooting 2 12-31-1969 07:00 PM
