Prius Technical Discussion This is a discussion on Towing a Prius? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I searched around a little bit but haven't found an answer to this yet... I keep reading that the only ...
prius?, towing
Old 08-30-2008, 08:18 PM   #1
timwalsh300
Send a message via AIM to timwalsh300
Default Towing a Prius?
I keep reading that the only way to steal a Prius is with a flatbed truck because of the immobilizer. So does that mean that nobody could have my car towed if I parked it somewhere illegally? What kind of damage would a tow company cause if they tried?
Tim
timwalsh300 is offline
Old 08-30-2008, 08:48 PM   #2
rigormortis
Package: #5 Touring
Default Re: Towing a Prius?
they can damage the rear end if the angle of the tow is too high (towing from front)
or they can damage the transmission (all four wheels on the ground) by dragging it
in order not to damage the vehicle you need to either tow it with the front wheels on dollies (towing from front or rear) or with the front wheels off the ground, or by towing it on a flatbed (most safest)
stealing a prius with a flat bed is another hot topic as far as i am concerned, i thought about it, and i thought of 7 other ways to steal one.
i really do not want to start another thread going arguing this flat bed myth.
if your worried about parking illegally, then do not, heh. maybe the city parking enforcement will realize you have a prius and just boot it!
rigormortis is offline
Old 08-30-2008, 09:26 PM   #3
timwalsh300
I am not worried about getting towed. I only park in 3 places around the city (one near my apartment and two around my place of work) and I have a permit for each of them.
But the rebellious side of me almost wants to try this (or see someone else try this) someday... park in some private lot just to see the look on the tow-truck driver's face when he realizes that there is nothing he can do.
There is just something about tow-truck drivers, kind of like tax collectors, that makes me want to stick it to them.
...I swear I'm not a bad person...
Tim
Old 08-30-2008, 09:32 PM   #4
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 28
Originally Posted by timwalsh300 View Post
...But the rebellious side of me almost wants to try this (or see someone else try this) someday... park in some private lot just to see the look on the tow-truck driver's face when he realizes that there is nothing he can do.
Hi Tim,
The rebellious side of you should contemplate whether a typical tow truck driver would care about any damage inflicted on your Prius...
Patrick Wong is offline
Old 08-30-2008, 09:49 PM   #5
timwalsh300
Originally Posted by Patrick Wong View Post
Hi Tim,
I was hoping that it was totally impossible as some others have made it sound (saying that a flatbed truck was the ONLY way), unless the tow company was willing to drag it away with brute force (that's the kind of damage I had in mind).
But these posts make it sound like it really wouldn't be that difficult given a little bit of effort.
Has anyone here actually had their Prius towed against their will?
Tim
Old 08-31-2008, 05:52 AM   #6
rigormortis
Package: #5 Touring
if you are parked in a way that prevents the tow truck guy from hitching your car up, he will drag it a short distance no problem so he can hitch you up properly.
ive seen this on those repo tv shows!
Old 08-31-2008, 06:13 AM   #7
Ogo
New Prius Owner
Here in Slovenia, towing companies, who need to tow cars because of parking or other traffic violations, use flat bed towing exclusively. And it was not due to hybrids.
Here they also photograph your car before towing it out. It is easy anyway - digital cameras are cheap nowadays and pohotograph is very good evidence of parking violation.
Ogo
Ogo is offline
Old 08-31-2008, 10:42 PM   #8
jayman
I was parked near the Convention Centre about two years ago to attend a Home Show. It's sneaky parking on one-way Winnipeg streets, some restrictions are stricter than others.
According to the sign when I turned off onto the street, I was good until 6pm. I parked behind a large moving van, put in enough change to have a couple of hours, and wandered around the Convention Centre for awhile
I came out around 4:45 to NO Prius! And next to where the big moving truck had been parked, apparently directly across from the Convention Centre, parking was restricted much sooner. I knew what had happened, called Dr Hook to confirm, and got a taxi - yes a Prius taxi! - to pick up my car
They had remarked on the tow bill that the parking brake had been set, so they had used dollies on the rear wheels. No evidence of damage. Apparently their tow trucks are equipped with trolley jacks, so they can quickly jack up a corner and slip the dolly underneath
2004 Toyota Prius "B", Tideland Pearl
jayman is offline
Old 09-01-2008, 10:16 AM   #9
rigormortis
Package: #5 Touring
your supposed to dolly the front wheels!
Old 09-01-2008, 10:30 AM   #10
Patrick Wong
DIY Enthusiast
Friends: 28
Jay's post refers to the foot-operated parking brake, which operates on the rear wheels. Perhaps you are thinking of the Park function on the transaxle, which locks the front wheels.
It doesn't really matter which axle the dolly is placed on...
Towing with the Prius tgdetweiler Newbie Forum 4 03-14-2008 09:48 PM
Towing With Prius? Hytec Prius Main Forum 27 12-15-2007 11:51 AM
Towing my prius behind my RV slimwille Prius Modifications 12 11-01-2007 07:34 AM
Towing the Prius behind an RV compwolf Prius Technical Discussion 10 06-28-2006 03:15 AM
