| This is a discussion on Prius Throttle Controller from SigmaAuto.com within the Sponsored Commercial Sales forums, part of the PriusChat Marketplace category; To All, You can now fine-tune the throttle of your '04~09 Prius for better acceleration response. Check it out from ... |
| Silver Business Sponsor Join Date: Oct 2004 Location: Tyngsboro, MA
Friends: 0 | To All, You can now fine-tune the throttle of your '04~09 Prius for better acceleration response. Check it out from our SigmaAuto Prius page. Under the "performance table". Alternatively, Throttle Controller product page here: BLITZ Throttle Controller :: Sigma Automotive Thanks for your attention. Edward |
Friends: 59 | Very interesting.... Is this specifically for Prius? On Blitz web site, it does not list Prius as the supported car. |
Friends: 2 | +1 on very interesting. But I don't get it. The last thing I want down in the regen-no arrows-yellow arrows range of the go-pedal is more "throttle" response for small inputs. In this thread we discussed the idea of finding a way to open up or extend the amount of go-pedal input so that it would be easier to find/hold no arrow and yellow arrow glide states both above and below 42 MPH: http://priuschat.com/forums/prius-mo...utton-mod.html This would be the equivalent of getting less response for a unit measure of go-pedal depression, which is the opposite of what this gizmo seems to do. Or am I missing something here? [Edit] One other possibility: as suggested by one of the later posters in the above thread, maybe this gizmo is just altering the signals just before the throttle body, thereby having no effect on that portion of go-pedal movement at the beginning of its travel that determines regen-no arrow glide-yellow arrow "glide." This would avoid having to deal with the dual signal output of the go-pedal and any interference with the ECU/CPU that deals with those signals. Last edited by Rokeby; 10-21-2008 at 08:57 PM. |
| Engineer Join Date: Apr 2007 Location: Atlanta, GA
My Car: 2007 Prius Model: Package: #1 Thanks: 0
Plus- this thing adds another in-line component of questionable reliability into a very important chain of vehicle components. That and what I think I saw as ~$400 price! Don't do it. | |
My Car: 2010 Prius Model: N/A Package: G Thanks: 11
Friends: 8 | Quote:
http://www.blitz.co.jp/new-product/t...controller.pdf Maybe, they have not tested it on the NA model. Ken@Japan Last edited by ken1784; 10-21-2008 at 09:51 PM. | |
Friends: 59 | It is not listed on here: Throttle Controller : Blitz, Power Site I wonder if it can flash it's firmware to support more / different cars. |
| Senior Member Join Date: Jul 2008 Location: Maryland USA
Friends: 0 | Holy crap! $420? Just can't get past the cost - and the "Special order item from Japan. No return. No cancellation. No refund." footnote. Last edited by NeoPrius; 10-21-2008 at 11:38 PM. |
| Senior Member Join Date: Jun 2004 Location: hell
My Car: 2004 Prius Model: N/A Package: #9 Thanks: 9
Friends: 5 | to me it sounds as if it's only re adjusting the petal position... I can do that... if it was actually changing the fuel ratios (like most programmers) or throttle orientation non-via system speed... so.. individually changing power ratios... or even changing the set rpms for the ICE... this seems to do none of that. am i missing something? and 400+ bucks.. wow (had to add that) |
| blitz, throttle controller, throttle response |
| Prius PHEV Conversion Controller KIS Project (mine) | WizBandit | Gen II Prius Technical Discussion | 3 | 05-22-2009 01:04 AM |
| Bad idle/low throttle. fine at higher throttle? | robisaks | Gen II Prius Technical Discussion | 14 | 01-16-2009 12:47 PM |
| 20 new products added to SigmaAuto.com Prius e-shop! | Areometer | Sponsored Commercial Sales | 11 | 06-16-2008 08:41 PM |
| 2007 Yaris: To throttle, or not to throttle... | nomadic1 | Other Cars | 5 | 03-09-2007 06:34 PM |
| Throttle butterfly, NHW11 Prius | tochatihu | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 08-06-2006 01:34 PM |
