Go Back   PriusChat Forums > PriusChat Forums > Other Cars > Toyota Hybrids
This is a discussion on 4 WDI stuck in the sand ? within the Toyota Hybrids forums, part of the Other Cars category; Based on a 06 Highlander. I have a question about the performance of this vehicle on a sandy situation. I ...
Old 06-29-2009, 09:02 AM   #1
phc
Default 4 WDI stuck in the sand ?
I will be taking it on a road that I have been on before in a small four wheel drive.
It is a very sandy road and I was wondering if anyone has tested the 4WDI of one of these Highlanders.
Snow covered roads have been manageable for the most part.
Thanks for any feed back,
phc is offline
Old 06-29-2009, 09:07 AM   #2
djasonw
Default Re: 4 WDI stuck in the sand ?
It depends if it is the hybrid or standard gas model. They each have different systems. The gas version is more robust than the hybrid one. The hybrid version only has the electric motor driving the rear wheels. While that is great for street driving, any excessive slipping and usage of the system MAY shut it down (temporarily to protect itself from heat).
djasonw is online now
Old 06-29-2009, 09:30 AM   #3
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 14
If the tire load rating permits it, lower the inflation pressures for sand. You carry a reliable air pump with you in the backcountry, yes?
tochatihu is offline
Old 06-29-2009, 10:47 AM   #4
jayman
I would not take the HiHy or *any* 4wd with non-defeatible electronic traction control into sandy/desert conditions. No matter who makes the vehicle, if you cannot defeat the electronic traction control, you will simply come to a dead stop on fine sand
The FJ Cruiser has the same problem if you are in 2H or 4H, as the electronic traction control is on. The FJ Cruiser, like the HiHy, does *not* have a disable button for electronic traction control.
However, shift into 4L, the ETC is disabled, and you can then go through sand, deep snow, and deep mud.
Toyota also cautions that the HiHy is *not* designed for offroad use, light or heavy. The regular Highlander can be used in light off road situations, it even has hill descent control
jayman is offline
Old 06-29-2009, 12:43 PM   #5
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
I don't think 4WD-i can be used in the sand. I have heard of a few people getting stuck. Maybe they pushed it too far, thinking it works like a true 4WD vehicle?? Put it this way, just treat it like a 2WD vehicle (i.e. would you bring a 2WD vehicle to where you're going? If not, then don't do it in the HiHy).
Tideland Prius is offline
Old 06-29-2009, 12:49 PM   #6
hill
High Fiber Member
hill's Avatar
+1
We have the same version in the Lexus. It AINT 4wd. It's awd, and there isn't any feature about it similar to locking axles. If the drive slips too much, you'll get a complete disconect (unless you've pulled your speed sensor wire(s) ... but you didn't hear that from me).
hill is offline
Old 06-29-2009, 12:50 PM   #7
925PriusGuy
Winter Gray Prius Club Member
925PriusGuy's Avatar
Model: V
Package: Navigation
+11
I wouldn't recommend it... The rear wheels are electric driven and if I remember correctly there is a thermal lockout if you exceed a certain amount of rear wheel spinning... or something like that (sorry to be vague) I just remember that AFTER I purchased mine I figured out that it was not intended for off-roading. I think that the 4wd-i part is because of the rear electric motor...not a transfer of ICE power to the rear wheels.
925PriusGuy is offline
Old 06-29-2009, 07:54 PM   #8
phc
Thanks to all that have chimed in on this.
I have come to the conclusion that this would behave as most of you have described to me.
I know the behavior that of what a could expect. It happened with the Camry on very icy incline.
Thanks again. (No sand)
phc is offline
Old 06-30-2009, 01:16 PM   #9
jayman
I should caution that anybody who does that in "real" off road conditions with a HiHy or similar vehicle, has a good chance to fry some very expensive parts
jayman is offline
sand, stuck, wdi
How sand is made into silicon chip xsmatt81 Fred's House of Pancakes 1 05-28-2009 11:46 AM
traction control on sand small house Gen II Prius Main Forum 5 02-10-2008 01:24 AM
Tar sand oil.... no peak oil? Mirza Environmental Discussion 19 04-22-2007 08:57 PM
Dester Sand 2006 available at Ram Country Del Rio Texas bbaustin Dealers & Pricing 0 05-27-2006 03:07 PM
Salt vs. Sand Tideland Prius Fred's House of Pancakes 16 01-17-2005 04:51 PM
