Go Back   PriusChat > Toyota Prius Forums > Care, Maintenance and Troubleshooting > Toyota Prius Service Bulletins - TSBs
Toyota Prius Service Bulletins - TSBs This is a discussion on Back up signal within the Toyota Prius Service Bulletins - TSBs forums, part of the Care, Maintenance and Troubleshooting category; Originally Posted by marzprius Which company makes a beeper that works with the Prius backup lights? Thanks, Mario You can't ...
Old 12-18-2007, 10:04 PM   #11
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Nominated 3 Times in 2 Posts
Friends: 6
Default Re: Back up signal
Thanks,
Mario
You can't use a back up beeper light bulb. You have to physically install a beeper. You can get one at radio shack. All told cost about $10.00 and takes less than 30 min.
There is a sticky on it somewhere.
Godiva is offline
Old 01-09-2008, 09:44 PM   #12
cnschult
cnschult's Avatar
Talking Re: Back up signal
on ebay there is a universal back up sensor that sticks to the reverse lights and a sensor senses the white light and then beeps. any idiot can peel off & stick this on, but keep in mind that this will diminish the amount of light that the reverse light gives off making it harder for you to see objects behind you while backing up (especially with tinted windows).
And since who knows how those cheap ebay reverse beepers will stand up to repeated gas station car washes, don't bother. Instead you should only park forward-facing in your garage, when you are in parking lots, either back into the spot or pull through the 1st spot so your car is facing forward in the 2nd spot, thus eliminating the time you are in reverse.
Since this thread was originally dedicated to helping you eliminate the annoying reverse beeps inside the cabs, there is also a trick to eliminating the annoying seat belt beeping that involves almost the same steps, just do a google search for it, or maybe someone can post the instructions. I'm not telling you to drive w/o a seatbelt, but its nice to be able to drive off and put the seatbelt on a few seconds later w/o the annoying beep.
now if only there was a way to engage ev mode in the U.S. w/o voiding the warranty ? . ? . ? . i have the stupid engine coming on automatically after 7 seconds.
call me a control freak, but does anyone also wish there was a way to engage "engine constant on" mode to charge the battery? I was driving thru the rockies and I'd get up 1/2 up a mountain to a flat spot where i'd like the battery fully charged, instead it just went to about 2/3 full to maximize fuel economy, so when I met the next incline my battery didn't last long. Although I live in flat michigan, i don't recommend the prius to anyone living in mountainous regions until toyota gives us total control of our hybrid.
I want 3 modes: normal hybrid mode, engine always on mode, and ev mode. any1 agree?
cnschult is offline
Old 09-18-2008, 10:13 PM   #13
mybluegt
ON e-bay i found a replacement light bulb for 7440 with a beeper and a halogn light. It fits in the light assembly with a little bit of sanding and then it gives you a back up alarm and then disarm the inside beeper. works well.
mybluegt is offline
Old 10-03-2008, 11:12 PM   #14
dmdiver
dmdiver's Avatar
Package: #5 Touring
thank you! i will try that in the morning!
dmdiver is offline
