Stump the Chump!
Discussion in 'Gen 2 Prius Main Forum' started by ZC1, Jun 6, 2008.
  1. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    OK, I'm worn out from strutting around, swaggering with a new-found sense of self-righteous self-importance, as the ultimate CHAMP of CHUMPS! Even my dogs were cringing.
    Moving on, here's an intimate little picture. What and Where?
  2. Bill Merchant
    4,096
    87
  3. Bill Merchant
    4,096
    87
    Sine Die
    The fold-down center arm rest, built into the 60 side of the 60/40 back seat, is hinged on the side next to the narrower seat-back and the pivot is covered with the pictured plastic finger. I took the picture from the passenger side, looking down with the arm rest folded down.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    the only reason i didn't say it.. is because i have never seen plastic on my arm rest.. it seems almost like cloth to cloth.. where the other pieces are buried.
  5. Bill Merchant
    4,096
    87
    If you fold down the narrow side of the back seat, you should see the plastic cover just about flush with the top of the folded-down seat back.
  6. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Let's consider a slight modification to this thread game.
    Not only should you take difficult-to-guess photos from your stock Prius, but let's add:
    The option to take similar photos of modifications added to your stock Prius. The normal answer time limits and format applies.
    So can YOU in one post both name the "Location" AND it's "purpose" for the following item?
    (The item in question is black, surely you can see it.)
    ZC1
    Oh, Champ Bill was kind enough to hand the sceptre to me, after the 72hours had expired and he stumped everyone who posted. :)
  7. ZC1
    711
    Metro Detroit
    It's not exactly the most perfect picture for a reason, since I'm pretty much giving it's location away.
    ZC1
  8. ZC1
    711
    Metro Detroit
    You mean at NOON today (72hours after my photo post above), I will have stumped the audience??
    A hint?
    Let me see.... I was considering adding one to the other side of the car, but in usage I've found only one was sufficient.
    Hmmm...more hints?
    It works as described. Ehh....water does not seem to affect it (so far) or car washes are okay too.
    Last hint: I wonder when the battery will wear out?
    ZC1
  9. V8Cobrakid
    3,790
    152
  10. ZC1
    711
    Metro Detroit
    Okay, since my post lasted the 72hours without solution, I'll declare I'm a Chump Champ who has chumped no one and still gets a crown. LoL.
    Anyways, HERE IS THE ANSWER!
    The answer to the puzzler photo above (post #306) is:
    It's a coin battery powered light sensor.
    Oh..and it has a LOUD beeping speaker.
    It is placed directly over the magnification circle embedded in the tail light lens for the backup light.
    The reason for this object is:
    Since the Prius is somewhat restrictive in it's panoramic view of the landscape as the car is driven in reverse, this handy little object alerts bystanders/pedestrians that the car is indeed in reverse gear.
    Once the transmission (planetary gearset) is placed into "R", the backup light comes on which shines into a small little hole on the backside of the small black box placed on my tail light lens. The bright light enables a circuit which then emits a loud beeping alarm which sounds like a backing up forklift or a bulldozer.
    No other illuminating tail light nor the lights from another car cause it to beep, only the reverse tail light.
    There is a small square hole in the front to emit the sound.
    After a month or so of using it, it has continued to survive car washes, the hot sun beating directly on it, false alarms, and anybody trying to remove it.
    Question is: Does it really make people aware of the car?
    Kids on bikes 3 houses or more turn to look, pedestrians out for a leisurely walk stop and mouth the words "What the heck?". In crowded parking lots I see peoples heads turn as they try to locate the sound.
    Nevertheless, I'm sure I'll meet some people who don't seem to be bothered to locate the sound source and for those people I will eventually have rigged up an Electric Train twin air-horn to blast them to mithereens if they enter into a 180degree arc behind my vehicle while the tail light sensor is beeping.
    Any questions?
    Oh yes, the cost?
    I think it was $3 US dollars, or was that $4?
    ZC1
  11. V8Cobrakid
    3,790
    152
  12. patsparks
    10,664
    569
    Adelaide South Australia
    One wonders if, when reversing out of your garage in the wee small hours of the morning are your neighbours (and anyone trying to sleep in your home) considering buying their safety conscious neighbour a bunch of flowers or dropping a burning bag of dog turds on your front porch?
    After living for a year across the road from a "toot goodbye" I can tell you the burning bag of poo was looking mighty tempting. Fortunately someone got the message to the tooter first.
  13. patsparks
    10,664
    569
  14. Bill Merchant
    4,096
    87
    Poo? OOp? I sense a reversal of fortune. :yell:
    As a former chumpion, I declare game-not-over!
    Look at this and tell me what it is. And where, of course.
  15. Bill Merchant
    4,096
    87
    Chumped!
    OK, game over. :(
  16. dulecki
    dulecki New Member
    25
    Western Michigan
    Just saw this thread... that'd be the backup camera lens, no? And is that close enough on the location?
  17. Bill Merchant
    4,096
    87
    You're correct, dulecki, but the time limit had passed. However, as world-class PriusChat Chumpion, I declare you the winner.
  18. ZC1
    711
    Metro Detroit
    Well folks, due to all the news making Chumps out there, it's time to resurrect.....
    STUMP THE CHUMP !
    (yay, applause...the crowd goes wild..!!)
    Okay, boys and girls....Get all your tinfoil hats adjusted and name this item and how it's used.
    Remember, no cheating and no looking in the owner's manual.
    Sincerely,
    ZC1
  19. ZC1
    711
    Metro Detroit
    Same question for all you 2010 types.
    What is this very odd and hardly understood object?
    No cheating!
    Sincerely,
    ZC1
  20. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Aren't these just the shifter to shift the driving modes? Or maybe it's a trick question I didn't get?
